Oil usage with auto lube
- msavitt
Replied by msavitt on topic Oil usage with auto lube
got 3 DTs now and I got to say I love autolube pumps, it is such a cool device. No fuss/no muss, less smoke/fouling, better lube when I need it. And when I experiment with jetting it doesn't mess with the mix ratio
the manual instructions work terrific if the cables are correct and move freely and the instructions followed in the correct order.
27 Nov 2021 10:57
#21
- Youngdrakeo
Replied by Youngdrakeo on topic Oil usage with auto lube
Okay so flushed out the fully synthetic oil
Filled up with the belray mineral oil, adjusted the slack in my cables and also slacked off the pin and dot mark on the pump... And I'm still smoking like a train.. Under full throttle is doesn't bother me much but sitting in traffic/idle I'm putting out abit of smoke and still getting a wet pipe.. I'm a little hesitant to start altering the pump. I really dont want to seize her.
73 CT3 modified, 74 AG175 MX, 79 YB100 x2 , 79 GT 80 ,2015 ducati scrambler ,honda CT70
30 Nov 2021 11:03
#22
- msavitt
have you checked pump output?
service manual states how many cc's output at full throttle and idle with 200 turns.
I bought a nice graduated cylinder on Amazon for $10 and clamp it to hose with a hemostat
I think this is the only way to know for sure what's up
is Belray Mineral oil the best to use with my DTs? I have been using Lucas semi-synthetic
30 Nov 2021 11:09
#23
- adguy2112
Replied by adguy2112 on topic Oil usage with auto lube
White smoke? Wet side crank seal?
30 Nov 2021 12:53
#24
Replied by MarkT on topic Oil usage with auto lube
If pump checks out then I'd guess you might be a little rich on the a/f mixture?
Not that it's a problem but in my experience you can run a lot of oil... I use to race with 16:1... on the oil and have very little smoke if carb jetting is "crisp".
But before you lean out the carb and melt your engine remember that you heard it from a stranger on the Internet located on the other side of the world... don't take this as "advice"... just a possible cause.
30 Nov 2021 13:45
#25
- msavitt
Mark - you raise a good point. Of the last three DTs I bought, none of them had the proper main and/or pilot jets and or needed/needle jets in some combination and for some reason were always too lean. I would def check jet sizes before firing up any vintage bike because a lot can happen in 50 years as we all know
