Reed valve
  • TIGER500
  • TIGER500's Avatar Topic Author
Reed valve was created by TIGER500
Where can I get a carb service kits .Reed valve and gaskets for dt2 .not Chinese.i live in the uk
19 Oct 2021 02:55 #1
Replied by Gr8uncleal on topic Reed valve
 from Salisbury.
Ignore carb kits for everything except the gaskets - a lot of Mikuni parts still available new.
I hadn't realised that the parts lists were so silent on the intake parts for these models!
 However, a little foraging around leads me to believe that the part number for the reed is 311-13613 and CMSNL have some in stock. If you do buy from CMSNL, try and collate everything that you need into one order, so that you only get hit once for postage.
Piccies of your bike please!
Last edit: 19 Oct 2021 03:45 by Gr8uncleal.
19 Oct 2021 03:14 #2
  • TIGER500
Replied by TIGER500 on topic Reed valve
19 Oct 2021 06:15 #3
Lovely looking bike, although you might want to find another mirror!
What's wrong with your reed(s)? I'm not sure that they fail all that often.
19 Oct 2021 06:52 #4
Replied by ksours on topic Reed valve
Food for thought. Before you spend the money on a new reed valve. Take the reed valve off and inspect it. Mine was dirty and let light out around the edges and top. I took the reeds off and cleaned the block. I then re-installed the reeds flipped over ( top was still top). It passed the light test. The edge of the block was dirty enough to not let the reeds seat tight and flipping the reeds took out any relaxation they may have had.
19 Oct 2021 09:51 #5
