CT3 Speedo Drive Gear rusted to hub..........(Need advice on how to remove)
- Quartermaster35
CT3 Speedo Drive Gear rusted to hub..........(Need advice on how to remove) was created by Quartermaster35
This drive gear seems to be rusted to the hub......... any advice on how to remove?
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
16 Oct 2021 14:32
- Swoop56
Replied by Swoop56 on topic CT3 Speedo Drive Gear rusted to hub..........(Need advice on how to remove)
Probably equal measures of good penetrating oil and patience .
16 Oct 2021 14:37
Replied by RT325 on topic CT3 Speedo Drive Gear rusted to hub..........(Need advice on how to remove)
I've got mine off in the end by using long nose pliers & forcing on the teeth but wonder if you fitted a tube over it to protect the seal then apply heat down through the tube. Seal comes out easy enough & can re-use it if ya careful.
16 Oct 2021 15:25
- Quartermaster35
Replied by Quartermaster35 on topic CT3 Speedo Drive Gear rusted to hub..........(Need advice on how to remove)
I have been heating it on and off today but hasn't moved much yet........ Will be soaking overnight.
(Hoping hoping)
(Hoping hoping)
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
16 Oct 2021 17:32
Replied by MarkT on topic CT3 Speedo Drive Gear rusted to hub..........(Need advice on how to remove)
I've had some luck trying to rotate gear CCW by the flats so it climbs the little gear... works really good if little gear is stuck
16 Oct 2021 18:07
If all else fails is there room to drill a couple of opposing holes from the outside in to tap the back of the gear with a punch or nail. Best pull the little gear out if you have an un-do thingy & just get it out of the way. With that gear removed & if any slight movement you can work at it with more room just nosey pliers on the gear teeth--won't hurt it if you don't slip.
16 Oct 2021 20:21
- Quartermaster35
I gave up on removing this and ordered a different hub off of Ebay for $30...... Problem solved!
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
The following user(s) Liked this Post: LETSJET
25 Oct 2021 09:59
