1973 Yamaha LT3 Kickstarter Shaft
Replied by MarkT on topic 1973 Yamaha LT3 Kickstarter Shaft
Perfect!  Thank you!!
The following user(s) Liked this Post: littlemilo
12 Sep 2021 16:51 #11
14mm on the AT/CT as well.  So cover swap might work out great.
12 Sep 2021 20:14 #12
Replied by 69Attex on topic 1973 Yamaha LT3 Kickstarter Shaft
Hello, first post here, I just picked up a 1973 LT3/100 (the purple one, 10/72 build date) from this post I gather the kickstart is a problem? I say this because my bike has a slight bind in the kickstart mechanism, the splines on the end are fine, but need to look at the internals. Will a 72 LT2 shaft work as a replacement? Thanks
13 Feb 2022 17:20 #13
Replied by LETSJET on topic 1973 Yamaha LT3 Kickstarter Shaft
Pretty sure they are the same LT2 LT3 HT1 HT1B. I did a LT2 starter shaft replacement, pretty simple. Keep the kick start lever very tight as the splines are smaller, less of them, and they are prone to stripping.
13 Feb 2022 17:56 #14
Thank you, I will tear into the side cover tomorrow, appreciate the reply
13 Feb 2022 18:01 #15
