Ignition coil assy
- ksours
Ignition coil assy was created by ksours
CT3 ignition coil assy- #304-82310-30 . There should be a common replacement for this part. I found 1 at 120 euro plus shipping. Does anybody know of a cross reference that would work ?
19 Aug 2021 11:44
- shyted
Replied by shyted on topic Ignition coil assy
I used one for a TY 175 points type from Rex's Speed Shop at £25.00.
It works but i expect you could find something on ebay much the same.
That's if your not arsed about being original .
19 Aug 2021 13:57
- ksours
Replied by ksours on topic Ignition coil assy
Thank you- I found another at 2fastmoto. But I like that you have already tried it and it works. Thanks alot. Curious as to what the OHM putput is.
19 Aug 2021 14:21
Replied by RT325 on topic Ignition coil assy
Any old single wire ac coil should work, 'does for me', it's just the mounting that's a pain if different.
www.aliexpress.com/wholesale?catId=0&ini...+dt100+ignition+coil
www.aliexpress.com/item/4000762600020.ht...00007573770237%22%7D
Are you pretty sure you have a coil issue as often--'i think'--coils, even new coils, are deemed faulty when the problem lies elsewhere. Sorry--just saying.
19 Aug 2021 17:06
- ksours
Looking for a back up. This 1 is an original 73.
19 Aug 2021 17:43
- shyted
I haven't bothered to check but if you want i will .
Yes as RT says mounting some types is the pain in the hoop . I fashion a cardboard one first and then make one from Aeronol
Ill stick some pics up tomorrow my old cock sparrow
- ksours
Much appreciated.
20 Aug 2021 16:46
