Mikuni overflow leaks
  • principal282
  • principal282's Avatar Topic Author
Mikuni overflow leaks was created by principal282
Fuel issues around..  I repaired petcock with a new brass 45 mm tube that was perfect. Disassembled most of carb carefully, cleaned out crud.
after a few attempts it fired immediately and ran like a champ for 10 min. Flooded out. Got er going but flooded again.
I'm out of good ideas. Was feeling good about the fix til she flooded
New vm 22?
14 Aug 2021 12:04 #1
Replied by RT360Fan on topic Mikuni overflow leaks
Obvious suspect is needle valve sticking/dirty.
The following user(s) Liked this Post: MarkT, Bigdog302
Last edit: 14 Aug 2021 12:51 by RT360Fan.
14 Aug 2021 12:51 #2
Replied by MarkT on topic Mikuni overflow leaks
Float bowl to jet setter o-ring sealing good?
14 Aug 2021 13:07 #3
Also float level?  Some manuals are way off on spec.  Arms should be parallel to gasket just as valve closes.
14 Aug 2021 13:08 #4
  • principal282
Replied by principal282 on topic Mikuni overflow leaks
Could be a very worn needle and seat.
adjust float arms to parallel at close...we will see
14 Aug 2021 13:57 #5
  • principal282
Here are pics
14 Aug 2021 13:59 #6
  • principal282
Not leaking out the overflow. Started and ran around the block. Plugs foul
14 Aug 2021 14:40 #7
Replied by RT325 on topic Mikuni overflow leaks
Sorry, not related to the flooding but the jet setter with Oring looks like it 'may' not have the brass thick washer in there the hex looks like its recessing up the spout a bit more than i'd expect. Hope i'm wrong but 'is' important.
The following user(s) Liked this Post: principal282
Last edit: 14 Aug 2021 16:16 by RT325.
14 Aug 2021 16:15 #8
Float arms are generaly close to square on. Hook up the fuel while holding the carb upsidedown & see how much finger pressure it takes to stop it flowing--or another reason might show up doing that--although can't think what. Are the floats pins bent & floats rubbing on something. If they were bent outwards they'd get closer to the bowl sides as they rose up. Or conversely rub on the center part of the carb.
14 Aug 2021 16:21 #9
  • principal282
Thanks, it is in there though. Good thinking and thanks! I need all the hints I can get
14 Aug 2021 16:41 #10
