Ignition switch
- ksours
Ignition switch was created by ksours
CT3 Ignitions are pretty hard to come by and it seems pretty expensive. I have my switch and the previous owner apparently lost a key and now a screw driver is my ignition. Here is my concern. Will the anti-theft tumbler in the steering lock assembly part # 341-23408-01-00 work in the ignition? It makes sense that you would use the same key to lock the bike as the key to start it. Has anybody tried this approach yet?
- DEET
- Moderator
Replied by DEET on topic Ignition switch
They are not alike
29 Jul 2021 14:54
Replied by Gr8uncleal on topic Ignition switch
If you could find a donor ignition switch with jiggered wires, contacts etc, but with intact inner levers and springs, then a master locksmith with the appropriate reference book could probably rebuild it for you.
A donor switch from any Yamaha of the same period should do, and maybe other manufacturers as well. However, I don't know enough about the components of other makes to confirm the latter.
It might be that a tumbler from any other Yamaha switch of the period might just fit straight in.
30 Jul 2021 00:08
- landyr67g
Replied by landyr67g on topic Ignition switch
Hello - not wanting to hijack but I have the wrong ignition switch that came with my project bike I purchased earlier this year.
My bike is a '70 CT1B 175 (green) and the ignition switch plug does not match my original harness connector (ign plug is on left in attached pic. I have two brand new keys for this switch and will trade or sell if anyone out there interested.
Note: on CT1B bikes the switch is below the tank.....
Regards,
Joe
Regards,
Joe
The following user(s) Liked this Post: hhookmup
30 Jul 2021 10:53
- hhookmup
Replied by hhookmup on topic Ignition switch
Well I have a CT1B missing an ignition switch, so I would be interested. hhookmup
15 Nov 2022 08:49
- DEET
- Moderator
The ignition switch with a 3 pin harness is for an AT (125).
CT's (175) use a 10 wire harness.
15 Nov 2022 10:33
