Ignition Switch?
  • RT3Sam
  • RT3Sam's Avatar Topic Author
Ignition Switch? was created by RT3Sam
Has anyone replaced their ignition switch with an aftermarket one? Or does anyone know where I can find a replacement switch? Mine is starting to go bad, and I'm concerned about riding it to far away and breaking down.
Sam
27 Jul 2021 07:18 #1
Replied by alnarv on topic Ignition Switch?
They can be taken apart, cleaned .lubricated and re-assembled.
27 Jul 2021 08:01 #2
Replied by Gr8uncleal on topic Ignition Switch?
+1 to the previous reply.
Also, remove the tank and check the wires and block connector for breaks/cracks.
I don't know how to do this myself, so you'll need a little help from others and maybe do some research yourself, but it is possible to bypass the ignition switch with a single wire to the coil - this might help if the switch fails when you are out and about.
27 Jul 2021 08:12 #3
