Searching for a 47T sprocket for my DT3
- Yamadude
Searching for a 47T sprocket for my DT3 was created by Yamadude
Hey,
I am wanting to replace the worn 47T driven sprocket on my DT3.
They are currently unavailable online. OEM # was 214-25447-10-00
Parts Unlimited apparently makes them but they are backordered.
JT Sprockets seems to make an item for ALMOST every bike in the world, but the DT3 is not in their catalogue.
Yambits offers the essential measurements (see below).
Got one ?
Got one ?
You can just call me Dude.
Syracuse, New York
Syracuse, New York
16 Jul 2021 17:51
- swm
Replied by swm on topic Searching for a 47T sprocket for my DT3
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=384232295284&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Swoop56
Replied by Swoop56 on topic Searching for a 47T sprocket for my DT3
The JT sprocket catalog may have it listed under DT1/2 or RT1/2/3 . They all interchange .
The following user(s) Liked this Post: Yamadude
16 Jul 2021 21:19
Replied by MarkT on topic Searching for a 47T sprocket for my DT3
That diagram with measurements is out of the JT catalog
17 Jul 2021 06:34
- Yamadude
Replied by Yamadude on topic Searching for a 47T sprocket for my DT3
Thanks Guys for your assistance and comments.
I bought the NOS sprocket from Scooterboy.
Syracuse, New York
Syracuse, New York
17 Jul 2021 07:05
I'm curious to hear from the 250 experts on the stock rear sprocket tooth count.
My understanding is pre-74 the standard rear sprocket was a 44.
Then in 1974 with the engine redesign they changed the primary ratio (crank and clutch gear) from 21/65 to 23/65 and went to a 47 tooth rear sprocket because of the taller primary ratio.
68-73 = 44 tooth
74-76 = 47 tooth
(all have the same bolt pattern)
Is this correct?
68-73 = 44 tooth
74-76 = 47 tooth
Is this correct?
17 Jul 2021 08:07
- Swoop56
My parts books back up Mark .
All the 250's and 360 / 400 68 - 76 use the same bolt pattern .
68 - 73 44T stock , 74 - 76 47 T stock ( 250's ) .
The following user(s) Liked this Post: MarkT, Yamadude
