Brakes 73 dt3
  • principal282
  • principal282's Avatar Topic Author
Brakes 73 dt3 was created by principal282
Going really well so far!!
Quick question that grease fitting doesn't fit a normal gun. Can I replace it or is there a different adapter I need for my gun? I know not  ton of grease but a little would be good.
Brakes and actuator arm were rusted solid. .
24 Jun 2021 09:21 #1
Replied by msavitt on topic Brakes 73 dt3
I think you need a gizmo like this. I actually think it works better than a zerk in tight spaces cause it doesn’t leak grease all over the place.
www.amazon.com/dp/B0779FK9CZ/ref=cm_sw_r..._encoding=UTF8&psc=1
Don’t forget to light lube cam pivot and contact points too.
hope this helps
24 Jun 2021 09:58 #2
  • principal282
Replied by principal282 on topic Brakes 73 dt3
Thank you!!
The actuator was stuck shut. So yes cleaned up lubed up!!
24 Jun 2021 11:24 #3
  • principal282
Finally done.
I have to say a shop will do future tires because aarp me can't wrestle tires like 21 year old me.
That said, it just took patience and reading when I got stuck. Everything moves and spins freely, brakes hit nice and work. Front n back done.
The following user(s) Liked this Post: RT325, Gr8uncleal, Sneezles61
25 Jun 2021 15:31 #4
Replied by Mothersbaugh on topic Brakes 73 dt3
Excellent job!
The following user(s) Liked this Post: principal282
25 Jun 2021 21:28 #5
