1982 DT2 250 blew hole in piston
- wbrewstersr@gmail.com
Replied by wbrewstersr@gmail.com on topic 1982 DT2 250 blew hole in piston
It has window holes
16 Jun 2021 22:28
#11
Replied by RT325 on topic 1982 DT2 250 blew hole in piston
DT2MX piston, slipper type. I see a two ring set in top pic. I'm not sure they ran a keystone ring on those. 'Tapered top surface of the ring'. Would have a K on top of the piston if it's keystone. Hope one of the rings in you new set is right for the job. I'm sort of familiar with those pistons--but was 50 years ago lol when my race bike was new & changed the piston & ring after so many races.
Thanks I will need to do some more research to see if I can use one ring out of the new set or need to order different one
16 Jun 2021 22:53
#13
- Sneezles61
Replied by Sneezles61 on topic 1982 DT2 250 blew hole in piston
scaring me... I'm just starting this journey.. eh..
How do you figure out if yer lean or rich? Sumthin' you do by ear perhaps?
Sneezles61
Sneezles61
17 Jun 2021 05:35
#14
Well something melted the piston after doing some research it shows that the timing is probably off the plug was to hot the needle jet valve in the wrong position carburetor needs cleaning and I need to check the intake for leaks
i am hoping the crank seals are good but all the other things I mentioned I will be checking
17 Jun 2021 08:17
#15
- DT400FRANK
Replied by DT400FRANK on topic 1982 DT2 250 blew hole in piston
The needle jet will not cause a lean condition because it's mostly open I think at 1/4 throttle so don't worry about that. Pinging is a violent explosion that happens to soon and it basicaly hammers a hole in the piston. Running lean I think will get the whole piston hot and would cause a seizure and cylinder wall scoring also. I had a dt at one time and I had to put little wires through all the carburetor passages to clear it up, it was a head scratcher. A lean engine will not run real well at lower rpms (poping ,backfiring ,idling to high if you know the signs and a rich engine will not run at wide open properly, blubbering, bogging fouling plugs.
Replied by MarkT on topic 1982 DT2 250 blew hole in piston
Look in the Mikuni manual for the carb circuit overlap. The slide needle and needle jet are the metering parts that have the most effect at 1/4 throttle if I remember correctly...
Could be air leak. Intake manifold leak is not as common on early reed models... crank seals, base gasket, and head gasket are.
You don't need to remove flywheel to check timing... (and technically can't check timing with flywheel off) but while in there look for oily residue as that's almost certainly signs of the seal leaking.
Make sure you have an accurate way to determine the exact moment the points open. "Eyeballing" always results in advanced timing.
17 Jun 2021 08:49
#17
Thanks for the info I will look for oil residue hopefully I won’t find any I purchased a digital dial gauge that has millimeters on it i will be use that and a multi meter to check timing
17 Jun 2021 08:57
#18
Meter must have an Rx1 scale. I like analog meters... most cheap and/or "autoranging" digital meters don't work well if at all. They jump all over the place.
17 Jun 2021 09:35
#19
Yes I will be using an analog meter once all my parts arrive
17 Jun 2021 09:45
#20
