Where to buy, or what size are lower AT2 fork seals/gaskets?
  • ukdt125
  • ukdt125's Avatar Topic Author
Hi all, when I say the gaskets, I mean the smaller (copper?) ones that are used with the socket head bolts at the bottom of the fork? I'm in the UK and can't seem to find anywhere that has them (part no. 214-23158-00) but I was thinking If anyone knows the dimensions or an alternative that may fit, that could be useful, thanks!
13 Oct 2020 06:25 #1
13 Oct 2020 09:39 #2
www.mcmaster.com/standard-washers/sealin...s/for-screw-size~m8/
These are M8 (i think) better mic em though. Either way copper crush washers are commonly available from most hardware supply houses.
Fletch
1975 DT175B
1979 XS650
13 Oct 2020 09:44 #3
  • ukdt125
That's great thanks for the info.
The following user(s) Liked this Post: RustiePyles
13 Oct 2020 10:21 #4
I might be wrong but I think they are a fibre washer, not copper.
M8 fibre washers are readily available.
Yamaha CT3 (in bits)
13 Oct 2020 14:31 #5
  • ukdt125
Thanks, I'll check them out. Got some copper ones on order I'll test them out, see how I get on, if they're not up to it I'll try fibre.
14 Oct 2020 08:37 #6
Curious how the copper worked for you? I used copper crush washers and they are leaking. I'm on the hunt for fiber now.
08 Jan 2025 17:01 #7
I was wrong. It wasn't the copper washers that were leaking. It was the o-ring in the nuts. They just needed to be a little tighter. The oil was running down and appeared to be leaking at the bottom of the fork.
22 Jan 2025 18:11 #8
Are you talking an Oring in the screw on seal holder?. But I thought that only the earlier steel sliders AT/CT had that. Or am I on the wrong track.
23 Jan 2025 14:21 #9
