Hooker header heat shield wanted.
- mkparker
Replied by mkparker on topic Hooker header heat shield wanted.
I guess I'll try and revive this topic. I assume nothing ever happened with reproducing
the heat shields? I recently aquired a 175 CT1B that has a Hooker pipe.
I'd love to find or make a heat shield for it. Does anyone still have a sample,
scan, drawing or anything they want to share? If nothing pops up, I'll attempt
to make something by hand using pics from this thread.
Thanks!
Thanks!
20 Apr 2021 05:19
#61
- Mothersbaugh
Replied by Mothersbaugh on topic Hooker header heat shield wanted.
Man o man that bike looks nice!
20 Apr 2021 05:35
#62
- mkparker
20 Apr 2021 08:48
#63
- Badger52
Replied by Badger52 on topic Hooker header heat shield wanted.
Found this on another site. It shows several pics at different angles of a CT1 with a hooker header similar to yours.
pnwdualsport.forumotion.net/t1832-1971-yamaha-ct1-c-175cc
288501A
The following user(s) Liked this Post: MarkT, Schu, Pedalcrazy
20 Apr 2021 17:37
#64
- Schu
Replied by Schu on topic Hooker header heat shield wanted.
Man those photos are gold for somebody wanting to make their own heat shield. Since you have a pipe to measure the distance between the mounting holes you should be able to have the straight on photo blown up and plotted out on paper to the size where the mounting holes on the copy measure the exact same dimension as what you measured from your pipe. Then take that template to a tin knocker and have it fab'd up out of aluminum. They could use your pipe to form a proper radius around the perimeter.
The following user(s) Liked this Post: Badger52
20 Apr 2021 18:53
#65
- Mothersbaugh
Sounds like SCHU wants one of these heat shields BAD! With a little push, he might do all that paperwork for you!
20 Apr 2021 18:56
#66
- Schu
The paperwork I could do. But I'm no tin knocker. I am a mechanical engineering manager. So I'm sure one of my guys could take the photo and plot a paper template to the proper scale if I knew the exact distance between mounting holes.
20 Apr 2021 19:17
#67
- Mothersbaugh
You're a good man! Or in this case, you manage good men!
20 Apr 2021 19:32
#68
- mkparker
OK, here are some pics and measurements from my CT1. I will probably proceed with making my on. I'm not officially a "tin beater" but I've whipped
out a few things over the years.
looks like 10 11/16"
Distances to bend point.
Roughly 155 degree bend.
27 Apr 2021 08:08
#69
- swm
Replied by swm on topic Hooker header heat shield wanted.
27 Apr 2021 08:53
#70
