Fiber washer/gasket for oil tank banjo bolt
- littlemilo
Fiber washer/gasket for oil tank banjo bolt was created by littlemilo
Anybody got a substitute for the banjo bolt gaskets on the oil tank for the early bikes, specifically my AT1C? Yamaha part # 90430-10029-00 looks to be unavailable.
I tried Ace Hardware fiber washers and rubber washers cut to size, but the drip continues.
Most motorcycle problems are caused by the nut that attaches the handlebars to the seat
15 Aug 2015 18:08
- pntrbl
Replied by pntrbl on topic Fiber washer/gasket for oil tank banjo bolt
North West Vintage has them. Item 13. $2.49 ea plus the $10 shipping ....
www.nwvcp.com/pages/OemParts#/Yamaha/AT1...NK_%28AT1C_-_1971%29
The following user(s) Liked this Post: littlemilo
16 Aug 2015 11:14
- littlemilo
Replied by littlemilo on topic Fiber washer/gasket for oil tank banjo bolt
Thanks Bill!
Found one on ebay for $4 shipped, and one of my originals might still be ok. If not, I'll go that route for the 2nd one.
16 Aug 2015 12:27
- pntrbl
Good for you! When it comes to $10 shipping on a $2 part I start looking for options too.
18 Aug 2015 14:31
- RTD2
Replied by RTD2 on topic Fiber washer/gasket for oil tank banjo bolt
All, I need to resurrect this thread. This gasket (90430-10029-00) has become very tough to find. I bought a couple of the last ones that Yamaha made and they were completely useless, leaked like a sieve. As we all know Northwest is gone, and no one else shows them. I have tried a couple of other gaskets and none work, they have to be a hard rubber and the last ones I got from Yamaha almost looked like fiber.
I have tried red fiber, crush aluminum, copper and a combo aluminum with rubber insert with no luck . I know someone has a solution and I need it!!!
Mike
Mike
23 Jan 2021 18:58
Replied by MarkT on topic Fiber washer/gasket for oil tank banjo bolt
Try DEET... or maybe someplace like McMaster Carr.
23 Jan 2021 19:23
- Midlife Motor
Replied by Midlife Motor on topic Fiber washer/gasket for oil tank banjo bolt
Is there nothing close at a local hardware store that will work? I am going to try Ace Hardware as I need to replace the same washers on my CT1 oil tank banjo bolt.
23 Jan 2021 19:37
This is a really old thread... pretty sure there have been other threads on this topic with solutions? DEET and mdscott come to mind... as did someone finding them at McMaster Carr.
I'll see if search comes up with something.
23 Jan 2021 19:45
Another old post with the McMaster-Carr number: yamaha-enduros.com/index.php/forums/gene...line-questions#29310
23 Jan 2021 19:55
- HouseofEnduro
Replied by HouseofEnduro on topic Fiber washer/gasket for oil tank banjo bolt
For the past couple years I have been using a red poly-fiber washer that comes in this assortment from Harbor Freight, I've used it on at least a dozen leaky tank/banjo bolt fittings so far and have experienced 100% success rate. Size appears exactly the same as the black original ones.
www.harborfreight.com/54-piece-washer-se...ssortment-67667.html
The following user(s) Liked this Post: MarkT, Schu, Jack
23 Jan 2021 23:54
