'71 RT1-B '72 RT2 Wiring Harness Compatible
  • rcederblom
  • rcederblom's Avatar Topic Author
I just bought a RT1-B with almost no wiring harness. I've located a RT2 complete harness. Is the RT2 harness (mostly) compatible with RT1? I do intend to use as street legal so will use as least a head, brake & tail lights.
13 Jul 2026 15:43 #1
Replied by Swoop56 on topic '71 RT1-B '72 RT2 Wiring Harness Compatible
Largely the same but on a RT2 the ignition switch is located between the speedo and revcounter .
I'm pretty sure RT1 switch is under the fuel tank .
The following user(s) Liked this Post: Drac56
13 Jul 2026 23:54 #2
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic '71 RT1-B '72 RT2 Wiring Harness Compatible
CMSNL shows that the RT1B (1971) used the same clock mounted switch as the later RT2 etc.
14 Jul 2026 00:19 #3
Replied by Enduro nut on topic '71 RT1-B '72 RT2 Wiring Harness Compatible
KDI reproductions has the wiring harness.
www.kdirepros.com/default.asp
14 Jul 2026 05:50 #4
Replied by Drac56 on topic '71 RT1-B '72 RT2 Wiring Harness Compatible
My two Rt1’s, switch ( 1 mod plug and 4 pigtails), mounted under the tank.
just finishing up two new harnesses for these 2 im restoring…
a labor of love, trying to emulate the original connections, measure, strip, tin, crimp, solder, crimp and cover.
most of these harnesses get the job done i assume but be advised, they generally are just the main trunk… magneto, horn / light , tail light pigtails do not come with them so your using your old leads..
time vs cost of the purchase for a 1st time builder..  well .. im in the red time wise vs a KDI aftermarket for 199.. up to 250.. from others.
good luck.. test all your connections on the old stuff.
fyi, harness with key mod plug below tank, to a center mount key switch , between gauges would be a pretty easy pigtail to build, along with the associated loose connections, 2 male two female should that scenario ever present itself.
cheers
Drac
On another note, can someone tell me what material ( clear connection cover on female 4mm plugs) Yamaha used to allow a heated fusion behind the connection without burning (cutting through) .
14 Jul 2026 11:42 #5
Replied by Mark350 on topic '71 RT1-B '72 RT2 Wiring Harness Compatible
1971 RT-1B ignition switch is betweem the tach/speedo as was the1972 RT-2.
15 Jul 2026 18:31 #6
  • rcederblom
Replied by rcederblom on topic '71 RT1-B '72 RT2 Wiring Harness Compatible
Thanks every one. AI + the parts manual shows the same count of external wires exiting the harness,so I ordered a RT2 on eBay.
Based on another suggestion, I found & sells new RT1B harness for $88 + shipping of 35 Euro up to $400 purchase. Many other RT1 items in stock that I could not find in US which could justify shipping, or so I told myself.
Thanks All for your generosity to help.
Now to find a Stator, Ignition Switch, Coil & Tool Box cylinder for the Old
16 Jul 2026 00:28 #7
