69 dt1 250 the clutch shaft seems to have play - is this normal
  • gusto
  • gusto's Avatar Topic Author
youtube.com/shorts/OxyGJv6tM3w?si=57G4djt09f52jUx_
when the basket is on it seem to still move but seems like i could put in an extra washer in to get play out. having trouble with clutch working right.
15 May 2026 16:56 #1
The clutch basket will take that slack out. Don't forget you want some clearance for heat, etc. If it shifts ok, no factor.
edit:   Just noticed you said loose when nut on basket too.   All the spacers there?
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1973 Yamaha DT3 250
1974 Yamaha DT125A
Last edit: 15 May 2026 17:45 by pabdt.
15 May 2026 17:42 #2
If you have the thrust washers and spacers installed correctly with the inner basket nut tight, the SHAFT (and inner basket) will have zero end play.
So what you're doing in the video is kind of pointless, unless the SHAFT still moves like that with the nut tight?
15 May 2026 19:19 #3
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=114138446913&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • gusto
when its all together the outer basket still has the same play as that shaft does in video. wish i took a video of it too. seems like on youtube theres only a japanese video of assembly but they still say some parts in english like spacer and ball. i order some washers to make sure i got the right stuff in there. ill try to put it back with those washers. i put this together before and yes it was hard not to let washer splip behind spacer. it seems like partzilla diagram is missing the gear in diagram so i hope its right. partzilla.com/catalog/yamaha/motorcycle/1969/dt1b/clutch
thx for help
16 May 2026 00:47 #5
Trying to do this on phone as too lazy to get outbof my armchair lol. The flat bearing has the quite thin washer which sits against the kick gear "not shown" in the parts pic. The thin washer protects the flat rollers & the other side the rollers run against thick washer shown. Sorry, only harping on about that incase you have the thin washer the wrong side. Comon mistake that. There shouldn't be any shaft end play when the nut is on even if the basket might move a bit as it has running clearance plus there a spring cush in those so could move around. But not the center hub as nut holds it tight to the shaft. Shaft is held had over to the bearing in the case. Bearing in the case is retained by circlips. So in theory it should all be good & held over to the right.
Last edit: 16 May 2026 02:17 by RT325.
16 May 2026 02:13 #6
