skirt lengths
  • tvrc18
  • tvrc18's Avatar Topic Author
skirt lengths was created by tvrc18
Anyone have a 285 prefix single ring mx piston and an early piston port enduro piston to compare skirt lengths? I have an mx cylinder and an enduro piston I want to run together.
21 Jan 2026 20:05 #1
Replied by RT325 on topic skirt lengths
I'll look tomorrow if noone has the answer but it's about 5mm on the inlet side.could sit the cylinder loosely on & bring piston to TDC then see how much skirt is left showing in the inlet.
22 Jan 2026 00:10 #2
  • tvrc18
Replied by tvrc18 on topic skirt lengths
My crank is out being rebuilt. I could eye ball it just to see about how much may need removed.
23 Jan 2026 16:04 #3
Sorry i'm hopeless, just did it now & Std DT1 is 72mm front & rear. DT1MX is 68.4mm front & rear. I measured as near to the very edge of top as i could get then down to the skirt base using verniers on both. I guess the inlet side is more important for performance than shortening the exhaust side skirt. Took some pics but not sure i can post now my google photos is full. Might try youtube if can load a still shots & post a link. I sat a gudgeon into both for a pic. Cheers.
Ok here goes, think i loaded stills to youtube.
www.youtube.com/post/UgkxoFzIvOmGJDcAs86v5hU6k_lj87s9aHCo
Yay it worked. Might delete it eventualy when ya happy.
Last edit: 23 Jan 2026 17:41 by RT325.
23 Jan 2026 17:18 #4
  • tvrc18
Thanks I went to google and saw the difference, wonder if I should just use the mx piston? They are all over Ebay.
26 Jan 2026 15:59 #5
Up to you, if the cost isn't over the top. Might be able to sell your DT1 piston kit & recover some cost. I run an MX piston in my DT1 with a 32mm 360 carb. Been like it forever & goes well.
26 Jan 2026 16:26 #6
