Headlight hi/lo switch wiring question
- dogman
Replied by dogman on topic Headlight hi/lo switch wiring question
I did test the bulb and it's fine (continuity between the lug the green wire connects with and the black wire connects with).
I don't even have voltage at that green wire so it's something else. I'm testing voltage between green wire and ground (when running and main switch in position 2 of course).
01 Feb 2026 19:26
#11
Replied by MarkT on topic Headlight hi/lo switch wiring question
Yamaha wiring colors can be a little confusing, especially if a US model.
The hi-lo switch circuit is very simple. And since you have high beam, that means you have AC power coming out of the key switch to the handlebar switch.
In the headlight bucket, the solid blue (could be blue/white) feeds AC power into the hi-lo switch. When the handlebar switch is set to low beam, the blue wire connects to the solid green coming out of the headlight switch. When hi beam is selected, the blue wire in now feeds the yellow wire out.
Here's a screen grab from your video showing the part of the handlebar switch that matters for your problem. The blue wire in the center is the "AC power in". The solid yellow and solid green are on either side of the blue. When you slide the beam selector switch, you are connecting the blue wire in to either the yellow or blue out.
So either the contacts are not good in that section of the switch, or you have a bad wire green wire or green wire connection.
One thing to keep in mind is there is very little "load" when checking continuity with a meter. ( A good example of this is sometimes a car will play the radio when you turn the key on, but then when you try to start, a bad connection in or at the battery fails under the extra load and everything shuts off) Those solder joints in your switch don't look too good.
02 Feb 2026 03:51
#12
Another quick test is that, if I remember correctly, the headlight connector plug has 3 bullet connectors to the harness? Simply swap the green and yellow bullets at that plug.
If the headlight works now with switch in low but not high, you have a bad headlight or headlight plug.
If the headlight still only works with switch set to high, headlight is good but there is a problem with the green wire getting power from the blue wire with the switch set to low.
02 Feb 2026 04:13
#13
- dogman
"One thing to keep in mind is there is very little "load" when checking continuity with a meter."
Good point. I'm trying to learn more about electronics and this is a good reminder.
"Those solder joints in your switch don't look too good."
Agreed. I actually had to resolder the blue wire yesterday because it came loose as I was taking the switch apart again.
I'm really leaning toward bad contact in the switch between blue and green. I'm going to jump it there to see if it's a contact issue. Of course I have this pesky thing called work that I have to do today
02 Feb 2026 07:40
#14
Replied by Gr8uncleal on topic Headlight hi/lo switch wiring question
Make sure that the copper strips (plate?) in the internal switch are making good contact with the copper contacts on the fixed, sort of semi circular part.
02 Feb 2026 08:26
#15
- dogman
This was/is the issue. I disassembled the switch again and re-soldered the wires. While doing that I noticed there is some side-to-side play in the switch.
Both beams are working now but if I put a little lateral pressure on the switch it does break contact. It's good enough for me, I just want both beams working in case I need it for some reason.
02 Feb 2026 19:02
#16
Well done!
On some of mine with those two skinny copper strips, I've had to bend them slightly to ensure consistent contact.
I guess Asahi Denso (AD, the switch manufacturer) must have refined the switch over the years, as there are different styles of copper plates for both the movable and fixed parts.
Kawasaki models of the same era used near identical switches, and Kawasaki made the individual parts available to order.
Are the spring and ball bearing (bit of white plastic?) that maintain the pressure on the copper parts in good condition?
The following user(s) Liked this Post: MarkT, Swoop56, Snglsmkr, Ht1kid
This is actually something you're going to want to fix. If the switch breaks contact with the engine revved up, the voltage will spike and when contact is made again, the headlight bulb will fail. In fact, the switch is designed so that as you switch beams, contact is never lost. No "dead spot". Instead, both beams receive power momentarily as the transition is made.
Adding a Yamaha voltage regulator would probably prevent this and is a good idea.
The following user(s) Liked this Post: DVM, Swoop56, Snglsmkr, Schu, Ht1kid
03 Feb 2026 03:12
#18
