red mark on flywheel can you set timing from this mark or get a guage?
- gusto
red mark on flywheel can you set timing from this mark or get a guage? was created by gusto
1969 dt250 been posting alot about
red mark on flywheel can you set timing from it?
or do i need a guage? i have head with slanted plug hole so i gotta take head off.
can i just measure 3.2mm or think i should fork out dough for a digital guage with magnetic arm?
if you set your point gap shouldnt it be near time from setting the gap?
i just installed new points and went back too old coil and got spark so im celebrating getting spark back. dont know if it was worn points slider pad or me. probally me but now i have spark back!
20 Oct 2025 20:31
Replied by RT325 on topic red mark on flywheel can you set timing from this mark or get a guage?
Not sure the mark was colored originaly but maybe, good idea too. So the notch in the flywheel window?, if the tab is at right angles that comes of one of the coils then in a perfect world that should be 3.2. Those tabs get bent over 55+ years but it's a pain to need to pull the head. I just mark something like a nail at 3.2 held vertical down the angled hole. Touching top one side & bottom of the thread on the other side of the plug hole is pretty much vertical. Points breaking at that point. i'd do 'that' & see how close it is to the tab aligning to the notch. All done by points gap but i'm sure you know that. Ps, could then strobe it although that can keep you awake at night as they never seem to hold perfect. Not sure why--main bearing wear, points pivot wear & play. Best not top know sometimes. They're a forgiving old motors those first ones if things aren't perfect. I'd better add--that's only how i do things & sometimes i'm as rough as a bears bum, but i know what works for me.
- Enduro nut
Replied by Enduro nut on topic red mark on flywheel can you set timing from this mark or get a guage?
Yes i believe that is correct what RT325 said. The notch on the flywheel window you use to line up with a little table that one of the coil screws holds on. Like RT325 said those tabs get bent or in the case of my 360 is completely gone. Put the piston at TDC and gap the points at 14 thousands you'll be fine.
21 Oct 2025 09:57
- Yamaguchi
Replied by Yamaguchi on topic red mark on flywheel can you set timing from this mark or get a guage?
Was a Yamaha mechanic in 1972 and as I remember I could get a small swing on a multimeter when the points broke.
I'll be damned if I can get an indication on a digital meter. (1972 RT2 360) Also, both sides of the points show ground even when open, yet I have a spark. Don't know what I've missed in these past 53 years, hoping you can shed some light on this. Thanks.
25 Oct 2025 19:57
- Tom P
Replied by Tom P on topic red mark on flywheel can you set timing from this mark or get a guage?
Several years ago I got timed mine, making it so they would just open when it hit the mark. Then I made a little test light to check it, and it turned out to be perfect. I haven't touched it since then, 3000 miles later. I added tape to the mark in this video to make it easier to see.
youtube.com/shorts/Gu8YPB2Rvzw?si=7tKcv5GOfCY0XTHF
01 Nov 2025 17:57
