No Start, I'm stumped
Replied by Schu on topic No Start, I'm stumped
Sorry. I didn't notice you said impact gun. I use a half inch drive Dewalt drill motor. It doesn't have the hammer effect like an impact gun and it works fine.
16 Sep 2025 13:27 #21
Replied by RT325 on topic No Start, I'm stumped
I was only spin starting a little LS3 100. Doubt I could do it on a 250 but maybe if it had an automatic chainsaw style decomp in the spare plug hole it might work. Anyway I probably tighten my mag nut to twice recommended-- but I'd better not recommend that lol. Have done it on my 360 with plug out just testing spark. Think I was strobing the timing at kick start speed  come to think, & made easy work of it. I saw a random video once with someone starting a bike with a flywheel using a belt around the flywheel & around his scooter rear wheel minus the tyre. Or did I dream that haha.
16 Sep 2025 14:08 #22
Replied by darinm on topic No Start, I'm stumped
If it has good compression and it's not firing with starter fluid you're not getting good spark at the right time, full stop. That's why two strokes are so nice to work on! Fueling is an issue (or not) that can be sorted after it fires/runs on starter fluid.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
The following user(s) Liked this Post: pabdt, Brzn, 6bikegarage
16 Sep 2025 15:04 #23
"I saw a random video once with someone starting a bike with a flywheel using a belt around the flywheel & around his scooter rear wheel minus the tyre."
You didn't dream it. Snowmobiles came with a webbing strap for wrapping the primary clutch to start them when the pull cord broke, have had to do it myself, on a 900cc twin. Thankfully the clutch is pretty big so it gives a good ratio for pulling.
Like Schu I've seen it done with a drill too!
1972 Yamaha CT2 175
1997 BMW R1100R
2013 Yamaha XT250
The following user(s) Liked this Post: RT325, Brzn
16 Sep 2025 15:13 #24
  • Brzn
  • Brzn's Avatar Topic Author
Replied by Brzn on topic No Start, I'm stumped
Okay, Life gets in the way and it's been a while since I've updated this post. We finally got the bike going this morning and he's out riding it right now. 43 degrees and bright sun here in south central PA; too cold for my old bones, but not for a 19 year old!
The no fuel problem was due to the left side crank seal popping completely out stopping any sort of vacuum from being able to pull gas into the cylinder from the carb, we replaced the seal. We replaced the points and condenser and we now have spark again. One of our neighbors has a points buzz box, so stopped by his place to have him set the timing. The bike fired on the first kick!
I'm just hoping I don't get a call this afternoon that it stopped on him again. :)
The following user(s) Liked this Post: MarkT, Snglsmkr, Gr8uncleal, Ht1kid, pahiker
14 Feb 2026 10:03 #25
Good news. I've forgotten what bike but guess 125 175 which seem more likely to push out old seals. When you said 43 degrees I thought too hot as were Celsius in NZ haha. Thanks for the update.
14 Feb 2026 13:06 #26
  • Brzn
Yea, 175, 1971 CT1 in the US
Well, he said he went 3 1/2 miles close around home and it was running great, so he decided to go further. He was 6 miles from home, his cell phone rang, he pulled over, shut off the bike, answered his call and the bike wouldn't start again after he disconnected the call. I got a call to go get him. He's disappointed and doesn't want to spend anymore time on it today.
The story will continue...
14 Feb 2026 13:53 #27
Replied by pahiker on topic No Start, I'm stumped
Heat soak problem? Did he try to start it after it cooled down? My bike behaved like that, lost spark a couple minutes after shutdown. Leaving it sit for 20 or 30 minutes and all was good. New ignition coil fixed it.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
The following user(s) Liked this Post: Schu, Brzn
14 Feb 2026 14:29 #28
Damn. Need to video record what it does & how it does it. Does it fade away like running dry on fuel. Or cut off instantly like ignition. Or run misfiring erratically also like ignition, like source coil issues--or secondary coil. I don't know but I'm full of guesses.
14 Feb 2026 15:09 #29
  • Brzn
Not a heat soak problem, wouldn't start once I got to him a good hour after it shut off, it was good and cold. Last time I was with him (last fall) when it did this it seemed like it had run out of fuel, probably when the left side crank seal popped out causing it to lose vacuum in the crankcase not allowing gas to be pulled in. There's no misfiring, I did look the source coils over closely when we were doing the points and condenser and they both appear to be in good shape. I'm going to try to have him bring the bike back to me today to try and diagnose what's going on...
15 Feb 2026 07:01 #30
