GFrench- 1971 DT1F MX Restoration
  • GFrench
  • GFrench's Avatar Topic Author
  • Supporting Moderator
Replied by GFrench on topic Re:GFrench- 1971 DT1F MX Restoration
Update:
Had a little time this afternoon to start working on the Exhaust pipe for the MX Project...  As I detailed earlier the Bike came with a Stock pipe but Rick was kind enough to send along a Hooker Pipe with the bike when I bought it from him.
It was missing the Chrome Hooker heat shield which is ok as I want to try to make it look more original for the bike..  Since I do not have a true GYT pipe nor would I spend the money required to get one- Haha!
I am going to try to make my own heat shield that I think will work and look pretty good.
I am taking a Metal Mesh Gutter Guard i bought from from Home Depot- a whole $3.80 and to see if I can make this work.
The good thing is this metal is very easily manipulated to shape and form it as needed... First step was to lay it on the pipe and just start pushing it into place- bending  / curving where needed while trimming excess along the way.
With a little work it takes shape!
Its laying on the pipe pretty nicely-
I will need to clean up the cut edges a bit to make it looked finished.... then the issue will be how to attach it to the pipe.. the pipe metal is very thin and the mesh is likely aluminum or some sort...  Will try to lightly tac it in spots along the welded joints on the pipe to anchor it....I see multiple practice runs on scrap metals I have with same thickness in my future before attempting the actual pipe...
1971 DT1F MX 250
1973 RT3 360 "Black Widow"
1973 RT3 360
1976 IT 400 / redesigned as a 75 MX400
The following user(s) Liked this Post: Swoop56, Snglsmkr, pabdt, fmxr47, Ht1kid
Last edit: 17 Jul 2025 14:28 by GFrench.
17 Jul 2025 14:26 #21
Replied by DVM on topic Re:GFrench- 1971 DT1F MX Restoration
Looking really good Greg!!
The following user(s) Liked this Post: GFrench
18 Jul 2025 13:17 #22
Replied by pabdt on topic Re:GFrench- 1971 DT1F MX Restoration
what is the pump setup to run it through the filter? Seems like a great idea.
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1973 Yamaha DT3 250
1974 Yamaha DT125A
18 Jul 2025 14:15 #23
  • GFrench
Hey pabdt-
Yeah there are alot of mod videos out there on how to upgrade / add different things to make the cleaner work a little more efficiently.... I will be using PCS-1000 from Tractor Supply and it runs $55.00 for a 5 Gallon can and will need two of them to get the tank pump under solvent so want to get as much life out of the solvent as possible.
Here is the Video that explains the set up and this is the kit I ordered from him... you might be able to save a few bucks putting all your own items and fittings to make it work... but for me and sake of running all over town... decided to just buy it complete..  It is good quality parts and will use a standard PH8A Fram oil filter.
A couple of other things I am going to do... I am going to mount my washer on a Furniture Dolly - it will not only allow me to easily move it around my shop and also roll it into a storage space out of the way when not using.... In addition it will raise the washer up and additional 3" making it more comfortable to use.
One other thing I think I will also do... is to place the flex washer pipe connection inside tank closer to the pump box which will allow more open space n that front right corner for smaller parts vs that way is mounted in the Video.
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: MarkT, Snglsmkr, pabdt, Ht1kid, Sneezles61
Last edit: 19 Jul 2025 09:33 by GFrench.
19 Jul 2025 09:14 #24
  • GFrench
Just a little update... has been a bit crazy last couple of weeks and not much time in the shop..
I found a Perforated Metal sheet from Grainger and the price was pretty good for a 12" x 34" 20 gauge sheet with the same size holes and spacing that was on the GYT pipe... So I decided to maybe scrap the wire gutter leaf mesh idea and give this a try...
With a lot of hand trimming as you go and bending it to fit the curves of the pipe... I think it will work out pretty good to give my 1971 250 MX Hooker Pipe a somewhat OEM styled pipe.
Here is the first rough layout as the bending of the metal was being worked mostly by hand.
Still need to get the edges trimmed and cleaned up for some smooth outer lines and add the proper button head hex bolt for the shield.  I think this will give me the look I was going for...
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: Rick C., MarkT, 1971DT250, swm, Swoop56, Snglsmkr, pabdt, Ht1kid, Badrul, pahiker
Last edit: 13 Aug 2025 15:35 by GFrench.
13 Aug 2025 15:20 #25
Replied by MarkT on topic Re:GFrench- 1971 DT1F MX Restoration
Looks great!
13 Aug 2025 16:27 #26
  • GFrench
Replied by GFrench on topic GFrench- 1971 DT1F MX Restoration
Well finally able to get back in the Shop and continue with this project.... Has been a busy Summer with lots of outdoor projects for me to complete... now getting some free time to focus on moving this great project along.
Next step I will starting today is degreasing and cleaning all of the Gloss Black Parts so I can get the prep work Started / Finished to have them ready to go for a  Fresh Coat of Gloss Paint.
The finish should look great once I go thru my process....
Once these parts are finished the Reassembly of the 250 MX will begin!
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: Snglsmkr, Ht1kid, Sneezles61
03 Nov 2025 08:13 #27
  • GFrench
Time to get the BIG Gun out to do some scrub degreasing and blast away!
Grease and Grime  was fairly loose and broke down with the "Purple" Super Cleaner.
Now time to do a final wipe down and will start the Scotch brite process to remove all the gloss and smooth everything out to prep for first coat of paint.
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: Rick C., MarkT, swm, Snglsmkr, Ht1kid, Sneezles61
Last edit: 04 Nov 2025 12:52 by GFrench.
04 Nov 2025 12:51 #28
  • GFrench
As I continue to Prep all the parts that will be done in Gloss Black using the red Scotch Bright pads...  I have been thinking thru what Paint Options I will be using.
In the past I have always liked using Krylon Gloss paint as it does lay down a very nice smooth finish but can lack durability long term... and I know there are many other choices out there that are much better and will provide a strong - smooth coating.
My thoughts are presently that I will use a good black Epoxy ( high resin) paint then come back over it with the high Gloss SprayMax 2k Clear coat.
So I have decided to give the Eastwood Extreme Chassis Paint a try in an aerosol for this MX Project and then apply the Clear 2k.
The Eastwood paint provides an 85% gloss... so I am thinking I will just lightly hit it with the scotch bright pad just enough knock down the gloss to give the Clear a good surface for contact then apply the SprayMax 2k for a Solid High Gloss finish... we'll see how that works out.
Here are the features of the Eastwood Paint:
Eastwood’s Original Chassis Black Gloss is the perfect coating at the perfect price for any under car component.
  • Resists corrosion, chips and scratches
  • Resists brake fluid, fuel, solvents, UV
  • Matches OEM finish
  • Apply multiple coats without lifting
  • 85% + Gloss Level
I will be ready to start painting next week once I get everything ready to go... more updates and Pics coming.
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: MarkT, swm, Snglsmkr, Ht1kid, pahiker, Reed valve Richards
Last edit: 07 Nov 2025 09:26 by GFrench.
07 Nov 2025 09:23 #29
  • GFrench
Next need to start degreasing / cleaning up the engine... never a fun job but time to dig in with the WD-40 and paper towels!
Once the WD-40 is sprayed on-  the Oil- Grease- Dirt mixture that is caked on begins to breakdown and makes the removal of all the gunk a bit easier!
Still have a ways to go to get the outer engine 100% clean but it gets easier once you get to this stage.
Then you get what looks like a Crime Scene- Haha!
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: Swoop56, Snglsmkr, pabdt, Ht1kid, Sneezles61
Last edit: 07 Nov 2025 14:49 by GFrench.
07 Nov 2025 14:31 #30
