1970 AT1 (but probably any year 125) battery question
- nhsteve
1970 AT1 (but probably any year 125) battery question was created by nhsteve
Working on a '70 AT1 and need a battery. Online I see it as a Yuasa 12N7-3B, measuring 5.31"x3"x5,25". But I also see a Motobatt AGM battery (which I did not make note of either the model or physical size- sorry
I did a search of the site here to see what others are using and I did see the Motobatt name but no model. The reason I ask is that the one I get pointed to is definitely a different size than the Yuasa. Don't need one that doesn't fit!
Appreciate any suggestions!
12 Jun 2025 06:52
Replied by Gr8uncleal on topic 1970 AT1 (but probably any year 125) battery question
Motobatt MB9U is the sealed equivalent, and the size looks almost identical to your measurements.
12 Jun 2025 09:45
Replied by MarkT on topic 1970 AT1 (but probably any year 125) battery question
To confirm Alan's results: www.motobattbatteries.com/motorcycle-bat...nduro-1969-1971.html
The following user(s) Liked this Post: nhsteve, Ht1kid
12 Jun 2025 11:21
- Pete-RT1
Replied by Pete-RT1 on topic 1970 AT1 (but probably any year 125) battery question
The Yuasa 12N7-3B you mentioned is only rated at 70 CCA, so might not crank the engine with the electric start.
Agop uses the Motobatt which is rated 140 CCA on his AT1-E with a 175 top end and it will crank that when warm.
Yamaha CT3 (in bits)
The following user(s) Liked this Post: MarkT, nhsteve, Ht1kid, Agop
12 Jun 2025 14:36
- nhsteve
Replied by nhsteve on topic 1970 AT1 (but probably any year 125) battery question
Thank you all for the replies and information, especially the site info that confirmed the sizing and cold cranking amps. I'm not at the point of needing it yet, just getting things lined up.
Thanks again guys!
Thanks again guys!
13 Jun 2025 09:07
