Rt1mx rear tire size
  • Bore Monger
  • Bore Monger's Avatar Topic Author
Rt1mx rear tire size was created by Bore Monger
Greetings all...
.  My question is...will a 4.60x18 fit on a 1971 RT1mx?
1968 DT1
1969 CT1
1969 DT1
1970 CT1
1971 CT1
1971 DT1
1972 DT2
1973 SUZUKI RV125 (2)
Last edit: 31 Dec 2024 10:35 by Bore Monger.
31 Dec 2024 10:33 #1
Replied by MarkT on topic Rt1mx rear tire size
Tire sizes, especially knobbies using the old "inch" sizes, can vary widely in actual dimensions.  One 4.60 x 18 might fit fine, another might not fit at all.  There are even documented cases of a smaller size tire actually being physically larger than a tire from the same manufacturer/model that is supposed to be a larger size.
Sometimes you can find a tire dimension chart with actual dimensions. You'll quickly see "nominal" size on the sidewall really doesn't mean much ...especially in the old system.
The following user(s) Liked this Post: Buggin
31 Dec 2024 12:24 #2
Replied by Rick C. on topic Rt1mx rear tire size
The 70-71 RT1 (MX) and RT1-B (MX) manual that i have says 4.00x18 stock.
I remember putting on a Dunlop 606- 4.50x18 and sweating because the huge knobbies almost hit the swing arm. It worked but darn it was close !
I left the bigger tire ( 4.60x18 ) for my CR480 that has the poop to turn that monster tire.
31 Dec 2024 16:51 #3
