Rear wheel(rim) offset ct1 175 1970
  • Joe1028
  • Joe1028's Avatar Topic Author
Rear wheel(rim) offset ct1 175 1970 was created by Joe1028
Anyone know the rear wheel offset on a 1970 ct1 175.
bought bike with rear wheel disassembled. Built up and put wheel in swing arm...about where it should be by equal spoke protrusion in nipples.
  Is rim centered in swing arm? I have wheel spacers as they were , lh has seal wear mark on spacer so i know it is the correct location..
wheel is about 1/4" more to the rh side and i am worried if i move it left tire may hit chain guard...
a photo may help if no dimensions are available...
thanks...joe
Last edit: 15 Dec 2024 16:25 by Joe1028.
11 Dec 2024 10:19 #1
Replied by Ht1kid on topic Rear wheel(rim) offset ct1 175 1970
Greetings from Tennessee
you need to make sure your counter shaft sprocket and rear wheel sprocket alignment is correct
​​​​​​  i.imgur.com/oZbghCq.jpeg
 i.imgur.com/2b5bZb9.jpeg
11 Dec 2024 16:48 #2
Replied by RT325 on topic Rear wheel(rim) offset ct1 175 1970
How does it line up with the front wheel. String line from rear to front with steering straight ahead. Seems a pity to have to touch it as looks nice.
11 Dec 2024 17:15 #3
  • Joe1028
Replied by Joe1028 on topic Rear wheel(rim) offset ct1 175 1970
Hi, can you measure from the right (brake side) inside of swing arm to rim...
i used a divider to make it easier...
thanks ...Joe
15 Dec 2024 15:56 #4
  • Joe1028
Front wheel is not on....i was hoping some one could help by measuring rim position between swingarm...i used a divider and vernier to measure..
15 Dec 2024 16:30 #5
Replied by Schu on topic Rear wheel(rim) offset ct1 175 1970
Since the Lions were losing, I went out to the barn and took your measurement from my CT1B.
I used a pair of inside calipers and the checked the distance from rim edge to inside of swing arm on the right hand (brake drum) side. Then I measure the distance between the internal caliper tips using my highly calibrated vernier calipers. lol
1-7/8” [47mm]
imgur.com/a/YEC5QPM
15 Dec 2024 17:07 #6
  • Joe1028
 Well same thing with the Steelers...lol
thanks sir...let me see how that compares...
have a good one...Joe
16 Dec 2024 09:27 #7
  • Joe1028
Hi Bill...
Well it was perfect on the measurement...47mm on mine also..
thanks..
appreciate the time and help...
Happy Holidays...
Joe
16 Dec 2024 16:35 #8
Are yes, but is your wheel pointing straight at 47mm. Sorry just stiring. I'll measure mine later.
16 Dec 2024 17:39 #9
I thought about that too, because the same measurement on my CT1C was slightly larger, but I didn't want to muddy the waters.
Joe asked for a simple measurement and I took it.
16 Dec 2024 17:48 #10
