Coil
  • kitkatman
  • kitkatman's Avatar Topic Author
Coil was created by kitkatman
Hi, 1971 Rt1 coil HT lead has a deep cut in it. Can the ht lead be replaced or not.If not is there a good replacement available. Thanks.
20 Nov 2024 08:09 #1
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic Coil
Is it just the cover, or is the cut into the core as well?
20 Nov 2024 08:12 #2
  • kitkatman
Replied by kitkatman on topic Coil
Just the cover, but deep. Was just going to put heat shrink over the lead. I think over the years it has been shortened and it is a bit tight, but still works.
20 Nov 2024 11:15 #3
Replied by DEET on topic Coil
I restore the orange color DT1/RT1 coils.
20 Nov 2024 11:45 #4
Replied by MarkT on topic Coil
Many cases of the inexpensive new coils advertised for sale not working so keep that in mind if you try one and loose spark.  "New" doesn't always mean it works.
Some coils had wire glued or sealed in to coil.  DEET said he's replaced those but it's not easy.  You might try contacting him.
On some Yamaha coils the wire threads in to coil like it threads into spark plug cap.
NGK makes a plug wire splicer, a bit bulky but they work.
Wire is solid copper core.  A NAPA store or small engine shop might have some
20 Nov 2024 11:56 #5
  • kitkatman
Hi Deet, The coil in question is the correct colour and is stamped HPE-H2. Also I have the stator which is stamped FZA - 1BL and in need rewiring.First of all can you tell me if they are compatible, The reason I ask is the engine I believe to be an Rt2 number RT1 145878 and rolling chassis number RT1 03705 (1970) I think. If you are able to restore them for me I can send photos to you.I have tried to contact you on  This email address is being protected from spambots. You need JavaScript enabled to view it. but to no avail,can you send me the correct address please. Thank you,  Alan.
28 Nov 2024 08:42 #6
That is my correct email, but I have not received anything.
You do realize that "This email address is being protected from spambots. You need JavaScript enabled to view it." is an email address and not a website, right?
What is your email address or phone number? I will try contacting you.
28 Nov 2024 19:55 #7
  • kitkatman
Hi Deed, Thanks for reply, my email address is  This email address is being protected from spambots. You need JavaScript enabled to view it.. Regards Alan.
29 Nov 2024 02:50 #8
I have emailed you.
You might want to check your spam or junk mail folder.
I also sent you my phone number in a private message here on the forum.
29 Nov 2024 17:36 #9
