RT1 360 UK project
- Tinker man
RT1 360 UK project was created by Tinker man
Hi all,
hopefully this is posted in the right place. I posted a few times to inform the group that I was getting 3 bikes, AS1,HS1 and this RT.
the RT needs most work. Lots missing and wrong. Unsure really where to start but I “think” I will try to make a bike to use and get as many parts that are period as possible whilst looking out for the right bits at the same time. If that makes sense. The bike is matching numbers RT1 - 02180 and should be black and yellow according to the UK reg document.
as can be seen from the photos attached some effort already gone into with the frame wheels suspension but I believe the tank to be wrong. Anyone know what it is off? It’s important as the seat is a home made wooden affair, with the hinge brackets screwed on. I want to put a correct seat on which I think can be bought new but will it fit with this incorrect tank? If not what seat could I fit? Open to ideas and thoughts on this please.
also the rear mudguard has been fitted in the wrong place on the frame too I think. Not sure why? Is the mudguard correct? Seems someone has welded a piece to the frame to mount it like this…. Not sure I like it so would probably put back to standard.
lots else missing including air box, chain guard, switches, bash plate, oil tank and lots more besides. I can only think to use eBay but shipping from the states is so expensive on eBay.
so many questions but will try to stick to the topic of tank, seat and rear mudguard here….
fingers crossed that you guys can help before I make expensive mistakes…
oh and engine doesn’t run…… yet….. but will one day.
cheers for now
imgur.com/a/UN0HMjd
cheers for now
imgur.com/a/UN0HMjd
I love taking stuff to bits - putting back together is another thing altogether.
01 Oct 2024 08:57
Replied by Gr8uncleal on topic RT1 360 UK project
Tank looks like it is from a 1972/3 bike. Probably DT/RT 2/3, but an expert will need sight of the underside, and possibly dimensions, to confirm.
I've got damaged switches that I'm trying to repair, but I'm a ways off a completed one yet.
Rear muddie looks like a generic one.
DK (aka twowheelspares) here in the UK may have a lot of what you need, and they can be haggled on prices. Some parts will be shared with other models. I'm happy for you to ask me any questions on parts before you buy.
01 Oct 2024 09:18
- Tinker man
Replied by Tinker man on topic RT1 360 UK project
That’s very generous of you GR8UNCLEAL.
I have a few bits in mind so will message you directly. Well, I will try.
I realise I probably asked too many questions in my post. I will try to be more concise in the future.
Thanks again, ian
Thanks again, ian
02 Oct 2024 07:53
Message received and replied to.
The following user(s) Liked this Post: Tinker man
02 Oct 2024 10:40
- Tinker man
Good evening from here in the uk,
I am now starting to put the bike together with parts sourced from the right sort of era even if not 100% correct.
i am also starting to think about getting a spark. I have the early model with the auto retard for starting and a spring set up on the points that has been mentioned many times on the forum. One question I have is how much movement should I see on the “lever” for the advance/retard in the flywheel window. 2-3 mm or more?I know I have to move this to the “run” position to set the ignition timing. I just don’t know how far it should move if that makes sense.
any help welcome.
best regards, ian
any help welcome.
best regards, ian
22 Oct 2025 14:07
