One spark, then none
  • Pete-RT1
  • Pete-RT1's Avatar Topic Author
  • Platinum Member
  • Platinum Member
One spark, then none was created by Pete-RT1
Popped round to help Bernie set his points/timing on his AT1-E after he had replaced crank seal, brushes and points.
Set the gap, set the timing by eye, rechecked gap, then with the plug out we checked for spark.
Pressed the magic go button, one spark then nothing.....hmmm, "try it again", pressed the magic go button, one spark then nothing.
I manually open the points and get a spark every time.
Try kicking it over, one spark then nothing.
Manually opening the points I could feel they felt "dampened" and weren't returning to close very quickly so we compared them to the original points which snapped shut.
Swapped the originals back in and all good.
Turns out the replacements are tight on the pivot meaning they haven't closed before the cam is lifting them again for the next spark, hence why we were only getting the initial spark.
I've now sorted the new points with some bearing oil and they're back in the packet ready for future use.
Was a new problem I hadn't seen before, so thought it might be a good one to share.
https://
Yamaha CT3 (in bits)
The following user(s) Liked this Post: MarkT, Schu, Ht1kid, nivlagusa, pahiker
Last edit: 09 Sep 2024 10:18 by Pete-RT1.
09 Sep 2024 06:36 #1
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic One spark, then none
What make are they, Pete - Few?
I guess could be caused by sitting on a shelf for 50 odd years and any lubrication drying out.
09 Sep 2024 07:58 #2
Replied by Agop on topic One spark, then none
Alan,,, it was from flee bay... item 364077416147
Bernard. ( UK - Berkshire )
Yamaha AT1e
09 Sep 2024 08:28 #3
  • Gr8uncleal
Thanks Bernard.
Few it is - thought I recognised the colour of the packaging!
09 Sep 2024 08:43 #4
  • Pete-RT1
  • Platinum Member
  • Platinum Member
Replied by Pete-RT1 on topic One spark, then none
Alan, they are made by Futaba.
Yes, likely new old stock and if there was any lubrication it may have dissipated over time.
I've seen Allen Millyard using that bearing oil on his points, so if it's good enough for him it's good enough for Bernie
09 Sep 2024 10:27 #5
  • Gr8uncleal
Thanks Pete.
FEW is, I think, a trading/product name of Futaba.
09 Sep 2024 11:05 #6
  • Pete-RT1
  • Platinum Member
  • Platinum Member
You are right as always Alan, just opened the packaging and FEW is there, Futaba is shown at the bottom.
09 Sep 2024 12:10 #7
Replied by RT325 on topic One spark, then none
Things that were sent to 'try' us. There's no end to them.
09 Sep 2024 19:31 #8
