CT1C wiring harness inquiry
  • Jogar
  • Jogar's Avatar Topic Author
CT1C wiring harness inquiry was created by Jogar
Howdy,
I recently purchased a ‘71 CT1C , and the owner hatched up the original wiring harness. I’ve got an ignition with the original connectors, but I’m wondering if anyone knows where to get a box of the other connector ends to clip into them.
edit: wondering also now that I’m thinking of it (which I think will be solved by switching out to an original ignition switch) the bike runs in key position 0 and 1, but dies in position 2. No clue why , has anybody encountered that?
thanks ! Pic attached through IMGUR
imgur.com/a/37tWUVb
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
Last edit: 30 Jun 2024 09:26 by Jogar. Reason: Additional thought
30 Jun 2024 09:24 #1
Replied by pahiker on topic CT1C wiring harness inquiry
It sounds like someone took the ignition switch apart and had an oops when reassembling if it's like the one in my RT3 There's a round plastic disc with connectors , it can go in one of two positions and if it's upside down it behaves that way. For connections, this could be a good place to look.
www.vintageconnections.com/
1973 Yamaha RT3
2024 Suzuki DR650
The following user(s) Liked this Post: Jogar
Last edit: 30 Jun 2024 09:56 by pahiker. Reason: Clarity
30 Jun 2024 09:50 #2
  • Jogar
Replied by Jogar on topic CT1C wiring harness inquiry
Thanks for that diddy of info re: the ignition. I’ll have to take a peek .
The prices on that site are pretty wild, I could pay the same and buy an entirely new wiring harness!
thanks!
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
30 Jun 2024 10:01 #3
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic CT1C wiring harness inquiry
Here's what the soldered plates on the underside of your switch should be (CT1C and CT2/3 are the same).
Vintage Yamaha Enduro Fans - 72 CT2 Ignition Switch (yamaha-enduros.com)
+ 1 to Vintage Connections - I've never found their prices excessive.
An alternative, and what I have done over the years, is buy old looms/harness just for the block connectors.
30 Jun 2024 10:43 #4
  • Jogar
I’ll take the cheap guy option! Thanks guys
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
30 Jun 2024 11:02 #5
Replied by DEET on topic CT1C wiring harness inquiry
I have one NOS wire harness left for the CT1 if you can't find what you want.
Email This email address is being protected from spambots. You need JavaScript enabled to view it.
30 Jun 2024 11:04 #6
