Stator numbers
  • kitkatman
  • kitkatman's Avatar Topic Author
Stator numbers was created by kitkatman
Hi, Could someone tell me what the numbers/letters mean that are stamped on the rotor&stator please.The ones on my 1970 rt1 are FZC-1A1L. G-6 which is the ones in the parts book. I also have a spare pair that are stamped FZA-1B/L. E-1 ( rotor) &FZA-1BL E-3 (stator ). Are my spares compatible. All help appreciated . Thanks Alan.
25 Jun 2024 13:51 #1
Replied by MarkT on topic Stator numbers
I'm pretty sure your spare set is from a DT1.  Not sure what you mean by "compatible"?  If DT1, it should "bolt on" and work just fine if you use the set...  I wouldn't do something like just use the flywheel from another set.
If you reach out to member DEET I'm sure he can explain the differences.
25 Jun 2024 14:07 #2
Replied by 1971DT250 on topic Stator numbers
Do either of yours have the mechanical centrifugal advance ignition timing mechanism?
25 Jun 2024 14:59 #3
Replied by RT325 on topic Stator numbers
Good point #3 if advance the points sit further out on the plate due to a fat cam on the 360 advance flywheel. Mind you the advance flywheel isn't flat across the face like all the others & is slightly but obviously convexed "not flat" slightly stepped.
25 Jun 2024 15:49 #4
  • kitkatman
Replied by kitkatman on topic Stator numbers
The main reason for the question was the numbers on the spare set being different ( e-1 & e-3 ), as apposed to g6 on the original one. The g6 one has the advancer on it so have to remember to set it. Very similar to pre unit Triumph.  Again thank you everyone for your answers.  Alan.
26 Jun 2024 03:11 #5
Just to confirm, the stator plates are different and not interchangeble with the different rotors. The rotor with the mechanical advance must have the corresponding plate.
The following user(s) Liked this Post: MarkT, Swoop56
26 Jun 2024 05:39 #6
