1971 Yamaha DT1-E Fuel Mix
- 2-smoker
1971 Yamaha DT1-E Fuel Mix was created by 2-smoker
Can't find my previous posting on this - will be running pre-mix due to a removed oil injection pump so I'd like to confirm a proper pre-mix ratio using Lucas semi-synthetic 2-stroke oil.... 1:24, 1:32 ??
27 May 2024 13:02
- Sneezles61
Replied by Sneezles61 on topic 1971 Yamaha DT1-E Fuel Mix
It all depends on how you ride… slow and mellow or hard and fast… oil is a friend… too much and the spark plug looks black… too little and the piston will seize .
Just a rough idea of where YOU start to figure this out.
27 May 2024 19:36
- Schu
Replied by Schu on topic 1971 Yamaha DT1-E Fuel Mix
I use AMSOIL 2-stroke Injector Oil at 32:1
28 May 2024 03:51
- 2-smoker
Replied by 2-smoker on topic 1971 Yamaha DT1-E Fuel Mix
Thanks - this will be just a 'slow and mellow' occasionally ridden bike that has been re-freshed/restored with its original motor (not rebuilt) - so just looking for a general guideline or recommendation for this particular model.
28 May 2024 09:06
