Tach/speedo mounting
  • motomike33y
  • motomike33y's Avatar Topic Author
Tach/speedo mounting was created by motomike33y
What is the secret to routing the light wiring under the tach/speedo to allow me to fasten washer/pins?  Just more compression of wire?  Seems to angle speedo/tach and make difficult to get pins fastened. 71 ct1
Last edit: 01 May 2024 07:28 by motomike33y.
01 May 2024 07:27 #1
Replied by Gr8uncleal on topic Tach/speedo mounting
They are a bugger! I'll try and get a photo of mine.
01 May 2024 08:25 #2
  • motomike33y
Replied by motomike33y on topic Tach/speedo mounting
Can photos be posted on here?
01 May 2024 14:04 #3
  • pahiker
  • pahiker's Avatar
Replied by pahiker on topic Tach/speedo mounting
Yes, use a 3rd party site like imgur. You can past the link or you can copy the bbcode for the pic to appear in the thread.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
01 May 2024 14:23 #4
Here are photos of mine.
I cheated/gave up on the tacho and routed them round the outside of the bracket (first two photos). Speedo one was ok (third photo).
The following user(s) Liked this Post: motomike33y
02 May 2024 00:04 #5
Replied by Brzn on topic Tach/speedo mounting
Patience and perseverance
Tiny fingers and thick calluses on the ends of your thumbs helps too!
The following user(s) Liked this Post: Quartermaster35, motomike33y
Last edit: 02 May 2024 04:14 by Brzn.
02 May 2024 04:13 #6
Replied by Schu on topic Tach/speedo mounting
Man those are some nice shiny parts!
03 May 2024 09:07 #7
"Man those are some nice shiny parts!"
Clearly not referring to my photos!
03 May 2024 09:52 #8
  • motomike33y
I finally succeeded by using a 1/4” aluminum strapping and two wood clamps so that I could tighten and compress the rubber to allow the pins in. I also cut the rubber trim to allow the tach wires to fit underneath
21 May 2024 16:53 #9
