what ignition coil works for a rt1
  • Nerdythrone567
  • Nerdythrone567's Avatar Topic Author
what ignition coil works for a rt1 was created by Nerdythrone567
i have a 1970 rt1 360 that needs an ignition coil partszilla says the part number is 214-82310-09-00 but when i search for it their is non available so curious what coils some of you are running
17 Jan 2024 07:55 #1
Replied by MarkT on topic what ignition coil works for a rt1
Contact member DEET if you want to stay original.  He may be able to help repair yours or may have one.
Otherwise the EMGO 24-71532 is one I've used a few times and has always worked great.  You probably will need to make a simple mounting bracket.
17 Jan 2024 10:28 #2
  • Nerdythrone567
Replied by Nerdythrone567 on topic what ignition coil works for a rt1
thank you MARKT for your impute probably will go with the EMGO ignition coil
17 Jan 2024 12:00 #3
  • Nerdythrone567
also this is my first enduro bike got it for free but needs a good amount of work need exosuit, piston rings, ignition coil, tires, condenser, and pretty much all cabeld stuff due to them being seized
17 Jan 2024 12:06 #4
Replied by RT325 on topic what ignition coil works for a rt1
Sounds like you have a bit of a project there.
Be great to see pics sometime if poss please but need to be loaded from some external site.
I don't know quite how it works but others use "imgur" i believe.
I use google photos, not sure why but that's where i ended up & i only seem to post a link to my pics so i'm probably not completing the process--but it works!!.
17 Jan 2024 14:49 #5
Replied by Ht1kid on topic what ignition coil works for a rt1
Nerdy don’t forget the brake shoes 50 yr old shoes can and will delaminate for safety reasons
17 Jan 2024 17:45 #6
  • Nerdythrone567
oh yah for sure i did put up a youtube video when i was younger  www.youtube.com/shorts/aY-pucel9lw?feature=share  a teacher gave it to me and i didnt have a vehicle so i walked it all the way back just havnt got around to it untill recently
18 Jan 2024 07:26 #7
  • Nerdythrone567
true I need to do that once i get it running and driving broke highschooler so might be awile
18 Jan 2024 07:29 #8
Replied by Gr8uncleal on topic what ignition coil works for a rt1
That'll keep you busy!
The rack will raise a tidy sum should decide you don't need it.
18 Jan 2024 07:33 #9
  • Nerdythrone567
so is the rack rare or something just curious becuse i took it off but i plan on taking off all the original parts to keep them presurved and use aftermarket parts. going to use this off road and  if i get the registration on roads as well but have to see if they do a bonded title in north dakota
18 Jan 2024 07:51 #10
