1971 Yamaha DT1E 250 Flywheel Magneto Removal
- 2-smoker
1971 Yamaha DT1E 250 Flywheel Magneto Removal was created by 2-smoker
I'm trying to remove my flywheel magneto and just want to confirm that the nut holding on the flywheel magneto turns counter-clockwise to come off. It doesn't want to budge just yet and before I reef on it - I'd like to know for sure.
I know the flywheel magneto puller I will use after I remove the nut from the shaft has left-hand threads and will install counter-clockwise.
13 Nov 2023 15:42
Replied by MarkT on topic 1971 Yamaha DT1E 250 Flywheel Magneto Removal
The only LH threads on the bike that I'm aware of are the 27mm x 1.0 ones the flywheel puller threads into.
(there could be some obscure LH threads inside the gauges or something)
13 Nov 2023 15:50
Replied by RT325 on topic 1971 Yamaha DT1E 250 Flywheel Magneto Removal
Yes flywheel nut comes of counter clockwise [lefty loosey--righty tighty].
You're correct on the puller being lefty tighty--27x1 fine thread.
Now i'm confused.
Now i'm confused.
13 Nov 2023 22:21
Gotta hold it solid although my pic shows tightening it.
But reverse for loosening--good holding tool & half inch drive socket with a long handle.
photos.app.goo.gl/fzY3dh5k5Z7gWUXFA
13 Nov 2023 22:31
- asco
Replied by asco on topic 1971 Yamaha DT1E 250 Flywheel Magneto Removal
Okay
This is certainly very important to the person who has never removed a flywheel before. ? …
once the nut and lock washer are removed the important step is:
the left hand threaded puller ( I like motion pro )
YOU
MUST
MAKE
SURE
THE
PULLER
ITSLF
IS ALL
THE
WAY
ON
UNTIL
IT
STOPS
TURNING
WITH
LARGE
CRESCENT
WRENCH
THEN INSERT THE PUSH PIN.
if you don’t have it threaded in all the way on
the left hand threads, holding the flywheel with your right hand and using a big wrench in your left hand you could possibly pull the puller out of the threads ..
if that happens oh boy!
AsHo
YOU
MUST
MAKE
SURE
THE
PULLER
ITSLF
IS ALL
THE
WAY
ON
UNTIL
IT
STOPS
TURNING
WITH
LARGE
CRESCENT
WRENCH
AsHo
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
The following user(s) Liked this Post: RT325, yamahahaha
13 Nov 2023 23:46
- 2-smoker
Replied by 2-smoker on topic 1971 Yamaha DT1E 250 Flywheel Magneto Removal
Thanks to all you for that confirmation.... and advice. Very helpful.
Now I'm read for the reefin' and get that puppy off for some new points, etc. Wish me luck.
14 Nov 2023 09:22
Unless the bike has a lot of miles or something is physically wrong with the points, I wouldn't change them. Parts replacing just to replace often ends up with issues, especially if using cheap modern replacement points and condenser.
14 Nov 2023 09:31
- 2-smoker
Hmmm.... good point (pun intended).
I believe ya. Being old school, I should have been thinking that.
14 Nov 2023 09:43
Replied by Gr8uncleal on topic 1971 Yamaha DT1E 250 Flywheel Magneto Removal
Definitely worth giving them a clean, though!
14 Nov 2023 09:53
As ASCO says--remove washers [there's a thick spring & a thick flat washer]. Hook them both out for the puller to get fully threaded in.
Also as stated leave the [push pin] puller bolt 'out' until puller body is fully home, or bolt can hit the crank & give a false indication of being fully home.
You only get one chance with the fine thread 27mm LH.
Just a warning, i have a puller here that isn't deep enough in the middle so crank hits it before fully home.
Not one i use, but same 27mm LH thread puller is used on damn near everything so might've been a genuine honda 50 puller from when we had both brands at work in the "60's until "76.
I'd think any puller on ebay etc would be plenty deep these days. Especially if marked for a DT1 or similar.
14 Nov 2023 12:29
