AT1MX pistons
  • Benjamin Fennell
  • Benjamin Fennell's Avatar Topic Author
AT1MX pistons was created by Benjamin Fennell
hi , can i run a 2 ring ATI piston in the AT1MX clyinder?
07 Nov 2023 13:24 #1
Replied by RT325 on topic AT1MX pistons
Probably can, but best to check where the ring peg [ring end gap] is for the lower ring at bdc. viewing in the inlet port.
Worst case is you'll just have to run the top ring only. My guess is it'll be ok but only one way to be sure.
Also the piston shirt on the inlet side will be slightly longer on the two ring piston, but won't hurt to shorten it to match unless there's strengthening bits inside the skirt at the bottom that will be removed.
07 Nov 2023 23:47 #2
