CT Oil Pumps
  • landyr67g
  • landyr67g's Avatar Topic Author
CT Oil Pumps was created by landyr67g
Hello - Anyone around experienced with the details of oil pump differences? Understand there is a former resident expert, but for what ever reason I can't get a hold of him.
Questions:
Other than the color coding, what are the differences between early '70's CT pumps?  Is a "364" pulley wheel same for all models...or just torque induction motors?  I now have a 364 pulley but also a 168, R1, 49301, that are kinda matching, to not even close.  They don't show up in the 1973 service bulleten #394 and curious what they are for.
Reason for all this is related to my previous "oil pump banjo" posting from a few wks ago.....the bike I bought had the wrong pump on it and I'm now planning to reconfigure it,and it seems like the wheel is the most significant difference.
Thanks for any comments,
Joe M
CT1B
26 Oct 2023 23:27 #1
Replied by asco on topic CT Oil Pumps
A CT1-B should have a Yellow dot pump with double banjo fittings. I prefer the gasket type ( 4 ) over the copper. The flow ratings on that pump I might have on something that came from Dickie Tower’s. You need to bleed it, and set the cable adjustment.
If it was an extreme duty bike I might consider going to a DT1 Black pump but would not run pre mix in the tank like I would the Yellow…
AsHo
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
30 Oct 2023 07:46 #2
