VAPE WIRING HELP, PLEASE!
Replied by MarkT on topic VAPE WIRING HELP, PLEASE!
You need to post pics to a free site like Imgur and then link them here.  This site has gotten too big and can't accept photo uploads right now.  I will PM you my email if you want to email them to me.
04 Aug 2023 09:19 #11
  • RT1
  • RT1's Avatar Topic Author
Replied by RT1 on topic VAPE WIRING HELP, PLEASE!
A HUGE THANK YOU TO MARKT
worked around the picture posting and problem resolved.
'68 DT1, '71 RT1, '71 JT1 (x2), '72 AT2 (x2), '74 DT250A, '75 XS650, '54 BSA C11G, '70 Honda CT70, '73 Hodaka Combat Wombat, '05 Moto-Guzzi Breva, '15 Triumph Tiger, +++
"We are mere custodians of mechanical things. Our job it to care for them, improve them and pass them on to others.” - Peter Egan
The following user(s) Liked this Post: MarkT, 1971DT250, Ht1kid
07 Aug 2023 11:09 #12
You're welcome RT1, you guys did the hard work...  wiring can get very confusing very quickly and you were able to help unravel the mysteries since someone had modified the wiring a little before you got the bike.
Great job and congratulations again!
P.S.  I'm experimenting using Imgur to post the short start up video you sent me.  I can take it down if you object.
[url=
][img][img]https://i.imgur.com/iAslfcK.mp4[/img][/img][/url]
The following user(s) Liked this Post: 1971DT250, Ht1kid
Last edit: 07 Aug 2023 11:35 by MarkT.
07 Aug 2023 11:33 #13
Let's see if this works:
imgur.com/iAslfcK Start up Video
07 Aug 2023 11:43 #14
I guess it did work, have to turn on sound at upper right when video opens on Imgur.
07 Aug 2023 11:45 #15
  • RT1
NO OBJECTIONS AT ALL MARKT.
The difference in starting and idling was immediately noticeable.  Very responsive to the throttle.  Smoother running overall.
Highly recommend.
I'll be doing the same with my XS650B sooner than later.
07 Aug 2023 11:58 #16
Replied by Ht1kid on topic VAPE WIRING HELP, PLEASE!
MarkT both of the videos worked fine
07 Aug 2023 16:51 #17
Replied by 71-yamahaRob on topic VAPE WIRING HELP, PLEASE!
Hello, I know this is an old thread but I am attempting the exact same thing on my 1971 RT1. Reading the previous posts, can anyone confirm if I connect the red vape regulator wire to -ONLY- the yellow, green, and green/red wires, or should I also connect the vape red regulator wire to the battery positive terminal in addition to the yellow, green, and green/red wires.
Thank you for the clarification,
Robert
1969 Yamaha L5T
1970 Yamaha L5TA
1971 Yamaha JT1
1976 Yamaha GT80
25 Jun 2024 14:20 #18
Post #2 was pretty clear.  And the way these threads go I probably repeated the same thing more than once.
That said, you can connect the VAPE to the battery if you want to.  But it won't work like stock as you'll be bypassing the "one way" feature of the stock rectifier which will prevent the headlight from coming on unless the engine is running.
If you're going to connect the VAPE directly to the battery, then you might as well ignore both green wires and the only other wire connected to the VAPE red besides the battery would be the stock harness yellow wire that went to the original stator.  Just tape up the greens.  Keep in mind that if you do this, the headlight will run directly off the battery whenever you turn it on.  Engine will not need to be running...  and it's easy to ruin a battery this way by leaving headlight on with engine off.  It doesn't take long for the headlight to completely drain a small 12v battery that fits in the stock box.  Your choice.
Last edit: 25 Jun 2024 16:59 by MarkT.
25 Jun 2024 15:25 #19
Hi MarkT,
It was clear until I got to the bottom where you mentioned that If I were to design my own system of wiring that the Vape red "needs to connect to the battery + to power the original battery powered accessories", hence why I asked if I needed to connect the battery + to the vape red because you did not specifically mention so when wiring the 3 others together.
1969 Yamaha L5T
1970 Yamaha L5TA
1971 Yamaha JT1
1976 Yamaha GT80
25 Jun 2024 17:04 #20
