DT1C Correct Carb Float Height?
  • Syd
  • Syd's Avatar Topic Author
DT1C Correct Carb Float Height? was created by Syd
Hello - Can anyone advise what is the correct float height is for a Yamaha model DT1C 250. I have two DT1 service books and one says it is 14.1mm and the other 15.8mm? Thanks
12 Jul 2023 16:06 #1
Replied by SKYDANCER46 on topic DT1C Correct Carb Float Height?
I have 3 DT1 250's, 68,70 and 71 Or had 3 now 2 and i set them at 15.1mm. I think 14.1mm was for 68 and or 69 models. Not sure about 15.8mm? I do know 15.1mm looks about right and level.
Last edit: 12 Jul 2023 16:57 by SKYDANCER46.
12 Jul 2023 16:55 #2
Replied by asco on topic DT1C Correct Carb Float Height?
Upside Down the brass float tab should be completely horizontal at a 90 degree angle matching the float chamber gasket. You do not need a measuring device. Just imagine the top of a T ..
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
12 Jul 2023 17:26 #3
  • Syd
Replied by Syd on topic DT1C Correct Carb Float Height?
Thanks for the info
13 Jul 2023 13:30 #4
