Need rear wheel bearing for my 1969 DT1B
  • rdhouck
  • rdhouck's Avatar Topic Author
Need to figure out where I can get bearings and oil seal for my 1969 DT1B. Numbers 9 and 10 on this diagram. Also spacers 35 if possible, otherwise I can Emory down the rust on mine. Thanks!
04 Apr 2023 15:56 #1
Replied by SKYDANCER46 on topic Need rear wheel bearing for my 1969 DT1B
On discontinued bearing and seals i just take them to my local Industries store that sells all types of bearings and they match them up. Always seam to have what i need. May take a day or 2 to get them in if they have to order.
04 Apr 2023 16:08 #2
Replied by Enduronut on topic Need rear wheel bearing for my 1969 DT1B
I have the seals . . . so many that everyone is welcome to buy them at just $3.75 each + 1.95 (for US shipping)
I probably have the bearing as well . . . can you give me any numbers found stamped into the edge ?
04 Apr 2023 16:49 #3
Replied by RT325 on topic Need rear wheel bearing for my 1969 DT1B
If i'm reading the middle part of the number right it uses two 6202 bearing double sealed & one 6204 double sealed in the sprocket carrier. That's the early wheel with square swinging arm QD wheel & good system it was too. #9 & #32
www.partzilla.com/catalog/yamaha/motorcy...1969/dt1b/rear-wheel
Last edit: 04 Apr 2023 17:01 by RT325.
04 Apr 2023 16:59 #4
  • rdhouck
Replied by rdhouck on topic Need rear wheel bearing for my 1969 DT1B
Bearing part no: 90387-20157-00
seal part no:  93104-4420-00
Collar part no:  90387-20157-00
would need 2 bearings, 1 seal and 2 collars if you have them.
05 Apr 2023 10:24 #5
Replied by Pedalcrazy on topic Need rear wheel bearing for my 1969 DT1B
I simply get whatever part number I need from the various sites that show exploded views and then search Ebay with something like "Yamaha (part number)" . You'll find various sellers will usually be out there and you can choose based on price, delivery time, etc...  I've restored a handful of enduros and rarely get skunked searching Ebay that way. I stick with OEM Yamaha parts.
The following user(s) Liked this Post: nhsteve, rdhouck
05 Apr 2023 14:37 #6
Replied by nhsteve on topic Need rear wheel bearing for my 1969 DT1B
While I agree that if I get OEM parts I should get OEM quality, I do believe that a 6202 bearing is a 6202 bearing, and should fit. The quality issue then comes up, and that is where going to a bearing supply house can be a huge bonus, as the counterman should be able to assist once he knows your application. Yamaha would have sourced and used bearings of a specific quality that was specified by engineering.
I believe that any bearing also has some additional lettering (maybe) to indicate tolerances of the bearing (yes?).
The following user(s) Liked this Post: rdhouck
27 Apr 2023 07:09 #7
Replied by Tinkicker on topic Need rear wheel bearing for my 1969 DT1B
Bearing factors.  If RTs memory is holding up, you need:
Koyo 6202 2RS C3 x 2.
Koyo 6204 2RS C3 x 1.
Take seal with you. The size is on the seal and unless it is a special regarding thickness, a good bearing stockist will have them in stock.
Better quality than OEM ( because penny pinching yamaha accountants usually tell production to fit Koyo 1RS bearings) and all at a fraction of the cost of buying them in yamaha boxes.
Last edit: 27 Apr 2023 09:20 by Tinkicker.
27 Apr 2023 09:04 #8
Replied by MarkT on topic Need rear wheel bearing for my 1969 DT1B
Good info except I don't ever recall a wheel bearing spec'd with the C3 clearance? Cn clearance (aka "normal clearance", which is usually not marked on the bearing) is what I recall for wheel bearings.
C3 for crank bearings? Yes. Just not wheel bearing. Could be wrong though?
2RS is a definite yes even if not originally spec'd... means a seal on each side of the bearing.
I'm also not sure it was "penny pinching" to specify a bearing with one seal or shield... most original wheel bearings have the open side placed where it is possible to wash the old grease out and repack with fresh grease without removing the bearing.
This is important because if you strictly follow ball bearing handling procedures, you NEVER hammer on the inner race and if you do, you replace the bearing. It's impossible to remove most Yamaha wheel bearings without hammering on the inner race so if a Yamaha Enduro wheel bearing is removed "technically" the bearing should be replaced... and new one installed only by tapping on outer race.
(In practice, most people that clean and pack with new grease remove the bearing and reinstall after... even though replacement is recommended if inner race was hammered on.)
27 Apr 2023 09:53 #9
In my experience, all manufacturers fitting 1RS bearings fitted them with the exposed side to the inside of the hub. Water gets past the dust seals, down the spindle and gets held inside the hub. Bearings rust from inside.
Never came across one fitted the other way from the factory.
27 Apr 2023 10:29 #10
