1968 Fuel tank brackets
  • Bore Monger
  • Bore Monger's Avatar Topic Author
1968 Fuel tank brackets was created by Bore Monger
I fabricated fuel tank mounting brackets for my 1968 DT1. I did not want to weld, drill or modify frame to use 1969 thru 1971 tanks.
  The brackets are also spaced out from the frame, as the 1968 is narrower in this area.
  This allows me to easily remove if and when a 1968 tank is used.
1968 DT1
1969 CT1
1969 DT1
1970 CT1
1971 CT1
1971 DT1
1972 DT2
1973 SUZUKI RV125 (2)
The following user(s) Liked this Post: Enduronut, MarkT, 1971DT250, swm, RT325, SKYDANCER46, bart.ives, JGersh, asco, nhsteve, Schu, Ht1kid, Sneezles61
Last edit: 20 Feb 2023 12:00 by Bore Monger.
20 Feb 2023 11:48 #1
Replied by nhsteve on topic 1968 Fuel tank brackets
Clever lad!
25 Feb 2023 07:42 #2
