Yamaha DT1-250C Front Fork Springs Question
  • Syd
  • Syd's Avatar Topic Author
Hello - Just assembling the front forks on my Yamaha DT1-250C and there are two springs for each fork, the main long fork spring and a small length (40-50mm long) spring which is the same diameter as the long main fork spring. Just want to make sure that the location for the smaller length spring is correct which I assume is located over the cylinder comp tube which is bolted to the bottom of front fork assy and then the longer fork spring is located above the cylinder comp and help in place by the bolt cap - is this correct?
04 Jan 2023 01:18 #1
