CT1B - Front fork with air suspension?
- YamCT1B
CT1B - Front fork with air suspension? was created by YamCT1B
Hi Guys
My CT1B (1970) has front forks with air suspension. I've never seen that before on this model. I can't find any documentation on it either. Were there any CT's with air suspension or was this front fork borrowed from another model?
Thank you very much and greetings from Germany
I can't post a photo here, it doesn't work somehow. :/
The following user(s) Liked this Post: Crazy Horse 124
Replied by Gr8uncleal on topic CT1B - Front fork with air suspension?
Unfortunately, photo posting is down at the moment.
Regarding your forks, aftermarket fork caps with valves in were a popular fitment for a while. If you have the original wheel hugging front mudguard/fender, as opposed to one mounted on the underside of the steering column, then it is likely that your forks are standard, but with the aftermarket caps.
The following user(s) Liked this Post: YamCT1B
27 Dec 2022 02:37
- asco
Replied by asco on topic CT1B - Front fork with air suspension?
This year I worked on a 1974 Honda MT 250 with Air Valves on the fork caps. The previous owner removed both short and long springs rendering them useless. Remove your caps and see if the 3” spacer and long springs are inside.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
27 Dec 2022 06:27
- YamCT1B
Replied by YamCT1B on topic CT1B - Front fork with air suspension?
You're right, those were just fake caps.
Thank you very much!
27 Dec 2022 23:17
- Tom P
Replied by Tom P on topic CT1B - Front fork with air suspension?
This thread reminded me that back in the early '70's I bought a short heavy spring kit for the CT-1 I had back then, that was just added to the existing fork springs. I removed the top cap, pushed them in, and replaced the cap. My current CT-1 has the stock forks, with original oil, and works beautifully. Never been taken apart. The top tubes were extremely rusty when I began working on it, so I avoided compressing the forks until I could knock the rust off, and get them as smooth as possible. 1,400 miles on it since, and still not leaking.
