Ct175 starter gear alignment
- Bore Monger
Replied by Bore Monger on topic Ct175 starter gear alignment
Will post picture when possible to do so.
1968 DT1
1969 CT1
1969 DT1
1970 CT1
1971 CT1
1971 DT1
1972 DT2
1973 SUZUKI RV125 (2)
1969 CT1
1969 DT1
1970 CT1
1971 CT1
1971 DT1
1972 DT2
10 Dec 2022 12:29
#11
- Bore Monger
My case uses small starter gear with flat spot as all my later gears are larger diameter and will not work. I would assume in my case it would use a larger diameter idler gear for proper mesh. Then the question is, does it use a different driven gear behind clutch hub?
Quite the conundrum!
I'm glad the planets are in alignment as it's working fine now!!
1968 DT1
1969 CT1
1969 DT1
1970 CT1
1971 CT1
1971 DT1
1972 DT2
1969 CT1
1969 DT1
1970 CT1
1971 CT1
1971 DT1
1972 DT2
10 Dec 2022 14:48
#12
Replied by Ht1kid on topic Ct175 starter gear alignment
Great news yea!!
10 Dec 2022 15:57
#13
- shyted
Replied by shyted on topic Ct175 starter gear alignment
Just a note on this. According to the Clymer manual,a segment in the GYTR tuning book says to use the idler and gear from a CT3 as they are cut differently and are stronger. I have put the idler and kick gear from the CT3 in both my CT1 & CT1B.
The following user(s) Liked this Post: MarkT, Gr8uncleal, Ht1kid, adguy2112
14 Dec 2022 07:06
#14
