What is this foam thing designed to do?
- SKYDANCER46
Replied by SKYDANCER46 on topic What is this foam thing designed to do?
All 3 bikes i recently bought, 68,70 and 71 DT250's have this foam piece under the gas tanks. Many bikes i have worked on in the past didn't have it, most likely long gone over the years. 2 of these the foam was glued or stuck to the frame. Was hard to remove from frame.
I always assumed it gave more support for the gas tank because you can definitely feel it when sliding the tank back on.
The following user(s) Liked this Post: MarkT, swm, Ht1kid
22 Nov 2022 19:15
#11
- nhsteve
Replied by nhsteve on topic What is this foam thing designed to do?
The '68 DT1 I am working on had remnants of foam glued to the top frame rail. I assumed it was there to dampen things and support the tank better. I will probably try to replace with closed cell foam to avoid water saturation. (who am I kidding, the only water it will see will be from the garden hose...
The following user(s) Liked this Post: AirborneSilva, Sneezles61
13 Jan 2023 08:48
#12
- automan
Replied by automan on topic What is this foam thing designed to do?
Isolates cables and wire harness from chaffing tank.
cliff
cliff
14 Jan 2023 03:13
#13
Replied by MarkT on topic What is this foam thing designed to do?
My vote is more support for tank.
14 Jan 2023 05:52
#14
