1971 DT1 crank dimensions
  • Doctor K
  • Doctor K's Avatar Topic Author
1971 DT1 crank dimensions was created by Doctor K
Howdy from Texas!  How do I find the crankshaft dimensions (I basically need the width of the crank between the two main bearings) for a 1971 DT1 250?
27 Sep 2022 09:17 #1
Replied by DEET on topic 1971 DT1 crank dimensions
Maximum 62mm
Minimum 61.95mm
The crank pin cannot be any longer than 62mm
Last edit: 27 Sep 2022 12:44 by DEET.
27 Sep 2022 12:43 #2
Replied by RT325 on topic 1971 DT1 crank dimensions
In theory crank width being in spec should give correct conrod side clearance so need to keep that in mind & i feeler blade the rod clearance as i press it up & i preload the press when getting close & tap the press--been a while-- maybe i tap the crank wheel just get it to creep a little until lightly biting on the blade at the desired rod side clearance. & now i can't remember how much clearance but probably 10-12 thou but don't quote me--or DEET correct me please?. But yes crank width has to be within what DEET said 62mm.
27 Sep 2022 13:51 #3
