Lean / pinging
- Hawksip
Lean / pinging was created by Hawksip
1971 DT250Bike is hard to start, have to open throttle to full to get it to start with the choke on. It is not flooding. Once started it pops and spits but smooths out in about thirty seconds of revving. It runs and aides great, very strong but when I take it on the road around fifty to fifty five mph in fifth gear with half to 3/4 throttle I hear what sounds like pinging. The ping goes away with acceleration or deceleration but comes back when holding steady throttle. Don't know if it is related but it also stops running when I turn the lights on. The bike started better before I did the following but was still pinging. Thoughts ?new piston and rings .25 overnew left side crank sealrebuilt oil pumprebuilt carburetor stock settingsnew plug BR8ES gapped at .018 gapnew points and condenser .012 gapcleaned exhaust pipe by cooking it out
20 Aug 2022 16:21
- 1971DT250
Replied by 1971DT250 on topic Lean / pinging
I experienced similar performance with that plug in a '73 DT3. the "R" indicates resistor plug. I put the standard non resistor plug B8ES in and it started and ran normal.
If you order B8ES from some vendors you will get the BR8ES.
Others have had good performance with the equivalent Autolite plug.
The following user(s) Liked this Post: Hawksip
20 Aug 2022 16:53
- asco
Replied by asco on topic Lean / pinging
Do a bubble test on the left seal with the spark plug tight.
If you have bubbles kick starting the bike with soapy water, get another one in there..
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
20 Aug 2022 17:05
Replied by Ht1kid on topic Lean / pinging
I switched to Autolite # 4054 = B8ES no problems with the Autolite
The following user(s) Liked this Post: Hawksip, AirborneSilva
20 Aug 2022 17:07
Replied by RT325 on topic Lean / pinging
Bit difficult to guess & depends what you call pinging which i relate to detonating but i'm guessing it's not that with points at 12 thou so theoreticaly fractionaly retarded compared to 3.2btdc. Regardless i'd open the plug to 20-22 & points to 15-, nipping 15 & then decide if you might be desribing richness blubbering on the needle. I think that because you say it doesn't do it if you open throttle a little more or roll it back under that point. If 'that' try raising the needle clip one notch at a time. I guess ya trying to be carefull after reboring understandably. Carb little Oring is critical but wouldn't rev at all if it's badly leaking letting fuel up the spout & bypassing the main jet.
Starting again i see you say needs full throttle with choke on which isn't good. Makes me think it 'is' flooding up. Try it from cold with no choke for a test. Starting to rethink the small Oring theory now.
One more poke. Restricted or blocked pilot jet can aid pinging as in detonating when rolling the throttle back on a hot motor. Probably more likely on a 360 as pretty temperamental with carburation. I had a guy come to me with a KX500 years ago & pinged & carried on but idled very lean, not realy wanting to run on constant low throttle. & was a blocked pilot jet. Long time ago & might've been the hole or both holes angled & straight up from the piolt out into the venturi that had something blocking it. Sort of one of those jobs you'll never see twice. Man was an arm stretcher down the paddock lol. Could get severely injured on one of those!!.
- Hawksip
Replied by Hawksip on topic Lean / pinging
Thanks, I will try this for sure.
21 Aug 2022 05:15
- Hawksip
Thank you very much, you gave me a lot to consider and it makes sense. One thing I have noticed about this forum is that just having some support thinking through or validating your thoughts is helpful to keep on track.
21 Aug 2022 05:22
- Hawksip
I changed to the auto lite and it did improve the way it ran but she still pings a bit
02 Sep 2022 15:25
- Hawksip
Well, I spent some time changing g plugs and the carb needle. While it ran a bit better it still pinged. I took off the flywheel just to check the points etc and found that I must have bent the points when I replaced the flywheel. After I straightened it out and set the points to .14 it ran much better. However the darn ping still audible at steady 3/4 throttle in fifth gear. I am going to run some premium to see if that helps. Funny thing is that the plug is now a nice gray. Maybe it is not pinging ?
02 Sep 2022 15:30
- AirborneSilva
Replied by AirborneSilva on topic Lean / pinging
Plug should be a dark brown, maybe I'm wrong but I say you're still running lean.
02 Sep 2022 16:03
