Piston size
  • yamahahaha
  • yamahahaha's Avatar Topic Author
Piston size was created by yamahahaha
Seller states piston is from a 1969 AT1........What size is this piston in picture???
Last edit: 29 Jun 2022 08:47 by yamahahaha.
29 Jun 2022 08:43 #1
Replied by MarkT on topic Piston size
Impossible to tell.
29 Jun 2022 09:33 #2
To clarify, it sounds like you want to confirm it's for a  69 125?  Can't tell from just that picture.
If you're certain it's a 69 125 piston...  remembering that a swap to 175 top end was common even back when these bikes were new...  then it's a standard size.
29 Jun 2022 09:37 #3
Replied by Swoop56 on topic Piston size
It might pay to verify if the piston is for piston port or reed valve engine .
29 Jun 2022 14:19 #4
Replied by RT325 on topic Piston size
If it's 56mm its a 125. If its has 'No Holes' [windows] its an AT1. Markings on top mean Std size. K means keystone taper top ring [or is it both rings]. Piston doesn't look to be stepped at the top for a Dykes L shape top ring so yep it's an early piston. But as said--squeeze seller for a bit more info or pics from all sides.
29 Jun 2022 16:11 #5
