How to Remove 2nd Gear?
Replied by RT325 on topic How to Remove 2nd Gear?
Ok, here we go. Kept searching untill found this in "73 CT3 & shows nothing, but can still see what looks like circlip grooves in the shaft. Be careful as think i'm right but happy to be proved wrong & don't want you to damage anything. Can you see a circlip as must be visible if there.
12 May 2022 23:39 #11
Replied by Pete-RT1 on topic How to Remove 2nd Gear?
Yamaha CT3 (in bits)
13 May 2022 00:00 #12
Just looking & looking & the shaft number is the same on ct1 & ct2 but no circlip on ct2.
13 May 2022 00:10 #13
click links above is easiest way to compare.
13 May 2022 00:15 #15
PETE-RT1 that puller would be in with a chance for sure if you could get it in back to front with the flat side against the gear teeth but don't think there's enough deeper down to bite on. That's "if" there's a circlip in there & my way won't work. I use one of those all the time to get crank bearings off but just smack it down behind the bearing & taper side gets them off.
13 May 2022 00:34 #16
Replied by mike8162 on topic How to Remove 2nd Gear?
Not sure if you're in the US but there is a new shaft on ebay for $14. Item#
373511994744
13 May 2022 15:40 #17
That's a bit of a bargain. New gear & new shaft, gotta be good.
13 May 2022 19:48 #18
  • landyr67g
  • landyr67g's Avatar Topic Author
Replied by landyr67g on topic How to Remove 2nd Gear?
Understood about new shafts, but then I would need to get ALL the gears if I can't take this thing apart.  I did see where the diagrams are different even though they show the same shaft. I took some closeups but can't  see anything between the gears....but you would think there's something because they don't spin like they are riding on each other (circlip on other side of stack is plainly visible). I will try a bearing separator tool to get the little one off and then truth will be told.  The separator style tool may be the trick.
Joe
13 May 2022 23:31 #19
I can't see a circlip after the stack [talking #6] expanding the pic, & wouldn't expect a circlip there. I'd think it would spin against the end of the splines with little gear pressed up to about 5 thou for running clearance to #6. Get a feeler in there & see what you come up with. My guess for the night!!.
14 May 2022 01:02 #20
