1968 DT1 Brass Breather Fitting
  • swm
  • swm's Avatar Topic Author
1968 DT1 Brass Breather Fitting was created by swm
There's been several 68 dt1 threads lately so just sharing an observation that I don't recall if previously has been posted.  When restoring DT1-00490 I noticed it had a brass crankcase breather fitting, so just an assumption brass may have been used before assembly line changed over to the familiar white fitting.  My next lowest VIN engine is DT1-0151x and it has the white breather connection.  If this is correct just creates another challenge when restoring these vintage jewels!!
Curious if Capt. Dave's very early #51 or Shawn's 0500 has brass fitting?   Others?
Regards
The following user(s) Liked this Post: MarkT, bart.ives, Sneezles61
11 Feb 2022 10:06 #1
Replied by JGersh on topic 1968 DT1 Brass Breather Fitting
This is from VIN # 0074xx and is white nylon…
correction to the above VIN #
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
Last edit: 11 Feb 2022 17:02 by JGersh.
11 Feb 2022 13:57 #2
Replied by Pedalcrazy on topic 1968 DT1 Brass Breather Fitting
Both of my bikes are white nylon. Early bike with no VIN appears to be between VIN 2800 and 3300 from some detective work…so interesting that 074XX is nylon as well as many others. No pattern emerging yet. Wondering if the brass one was a preference of some mechanic working on it back in a day?
Last edit: 11 Feb 2022 17:29 by Enduronut.
11 Feb 2022 14:21 #3
Replied by Enduronut on topic 1968 DT1 Brass Breather Fitting
I have an unrestored 68 DT1 that was just three bikes behind yours, coming down the assembly line ... # DT1-00493
Mine also has the brass fitting!
I'd say that pretty much proves the brass breather was an original piece on these early bikes, and not a replacement part.
Good eye swm! . . . haven't restored my bike yet, so I never noticed this before.
For the curious of mind . . . the yellow "plug" is a mice deterrent!  LOL
The following user(s) Liked this Post: MarkT, swm, Swoop56, Pedalcrazy
Last edit: 11 Feb 2022 21:14 by Enduronut.
11 Feb 2022 15:05 #4
Replied by type one on topic 1968 DT1 Brass Breather Fitting
Good spot that ….
my 01012 is white nylon ….
cheers
T1
DT1's mainly -
1968 AUS
1969 B scabby track bike
1969 B MX project
73 CT3 project
BMW GSA 2018
The following user(s) Liked this Post: Enduronut, swm
12 Feb 2022 00:40 #5
Replied by Sneezles61 on topic 1968 DT1 Brass Breather Fitting
So... any one go looking for the brass breather plug? Them nylon ones are very easy to break when dis-assembling..
Sneezles61
12 Feb 2022 06:35 #6
Replied by Gr8uncleal on topic 1968 DT1 Brass Breather Fitting
"Them nylon ones are very easy to break when dis-assembling."
And the ones that Yamaha supply now don't really fit properly either!
Last edit: 12 Feb 2022 06:57 by Gr8uncleal.
12 Feb 2022 06:57 #7
Replied by my68dt1 on topic 1968 DT1 Brass Breather Fitting
Another use for a T post hot wire clip
15 Feb 2022 10:00 #8
