DT1 Float Arm Height Adjustment
- DTDouglas
DT1 Float Arm Height Adjustment was created by DTDouglas
Hi Guys,
I have some photos attached. I have my 71 DT250 float arm parallel to the bowl, which leaves it at the Service Manual measurement "A" at 12.5mm.
The manual specifies 15.8mm, so if I bend the tab, my float arm will tilt down, like the orange line I drew. Is that correct, or is it supposed to be parallel to the bowl?
Also, is there a good source for the little caps that go on the tops of the float rods? Mine are so hard they will not go back on.
Thanks,
Doug
Thanks,
Doug
The following user(s) Liked this Post: bart.ives
18 Dec 2021 13:38
- msavitt
Replied by msavitt on topic DT1 Float Arm Height Adjustment
I could be wrong and often am, but the manual shows the carb upside down, so a higher "A" will lower the fuel level and therefore your line would be flipped along the horizonal axis. Also, if your needle has a spring dohicky within it, then the measurement is made when the tab on the float that you adjusts is just touching the needle titty without compressing the spring under said titty.
those little bead buggers are there I think to help you assemble the carb, none of mine have them and no issue.
The following user(s) Liked this Post: MarkT, adguy2112
18 Dec 2021 14:40
- asco
Replied by asco on topic DT1 Float Arm Height Adjustment
It’s correct as it is…
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
18 Dec 2021 20:23
Replied by RT325 on topic DT1 Float Arm Height Adjustment
Carb body surface is shown wrong in your manual pic. Should be at the gasket & can allow a mm or so for the gasket. Looks good as it is, parallel. That's how i do it without measuring--i think--been a while!!.
19 Dec 2021 03:01
Replied by MarkT on topic DT1 Float Arm Height Adjustment
Yamaha changed the measuring method... I think it was in the early days they measured from Jet Setter down... then later from gasket surface up.
Float level specs are often wrong and inconsistent in Yamaha literature... Parallel to gasket surface is what I have done for years after figuring this out.
And yes, caps are not needed... new Mikuni carb I bought didn't even come with them anymore.
The following user(s) Liked this Post: Bigdog302, Ht1kid, Pedalcrazy
19 Dec 2021 06:09
Always something to learn. & i'm still learning haha. Better look at my manual & see what it shows out of curiosity. But parallel always looks good. My little caps have long gone as by memory wouldn't go back on & don't want to bend the float pins trying too hard.
19 Dec 2021 13:12
