Hummmm !... look what I found !!!!!
  • Agop
  • Agop's Avatar Topic Author
Interesting find in my clutch basket !....
Has anyone experience that ?  It is on an AT1e 1969....
Bernard. ( UK - Berkshire )
Yamaha AT1e
Last edit: 05 Oct 2021 10:55 by Agop.
05 Oct 2021 10:49 #1
Replied by MarkT on topic Hummmm !... look what I found !!!!!
Yamaha had a few revisions and Service Bulletins for this and other kick gear issues.
So when buying parts, good to get a matched set and the parts from the later models are stronger.
(They finally gave up and suggested an engine mod to prevent kick start breakage around 72-73....  extra points if someone knows what that suggested modification was...  Enduronut mentioned it here once.)
05 Oct 2021 16:39 #2
Replied by RT325 on topic Hummmm !... look what I found !!!!!
Bugger. Now i'm worried about mine converted to 175. Don't recall ever seeing that from back in the day.
05 Oct 2021 22:01 #3
Or did it run backwards & lock up via the kickstart as all hell breaks loose if kick start is accidentally touched by ya leg if its running backwards at the time & weakest point goes first.
05 Oct 2021 22:04 #4
Replied by shyted on topic Hummmm !... look what I found !!!!!
Bernard,
I have one .Just checked the part number and it's the same as a 69 CT1 . I also have the associated
gear . It's used and has marks on it . Ill put pics up later . Or i have a a good unmarked fly wheel which you can have FOC just postage . You can remove the flywheel and replace the rivets with another means of fastening like tap the holes out and fit bolts with locktite green.
07 Oct 2021 01:05 #5
  • Agop
Replied by Agop on topic Hummmm !... look what I found !!!!!
Shyted,
Many thanks for the offer.
When I bought the bike from one of the Forum member he very kindly included a spare engine....  so I was able to swap the part !...
I am just struggling to remove the old gasket at moment.
Should be done this week-end...
Yamaha AT1e
07 Oct 2021 01:23 #6
